Also on another note, the engine bay is painted, the front subframe and arms are with the powder coater and I've ordered all the bushes to get the subframes built up and back on the car.
RS2 rebuild
This part?Digging through the parts I noticed this back plate was corroded and the steel clip has come off which I haven't found yet. How hard are these to get hold of? Or is it worth me trying to repair this one. IMG20240318160156.jpg
Urs6 plus project goneComment
Yes, it's there and same price.
I don't think you will easily find good second hand as they are Rs2 specific part and like rocking horse poo.Nothelle S2 Avant
i would go for a set of new ones. mine looked ok and after blasting them you could see several cracks in the brakets. danger in buying overpriced used stuff is big. 8A0615412 8A0615411 are the part numbers for them. trust me if you dont buy them new now in few years if your go bad you wont find anything.Comment
IMG20240325105840.jpg this vacuum line doesn't belong here I take it.
Is there anything above the tank to fit before I put it back in? Most of the bits are powder coated now so I'll start reassembling it.
Also where's the best place to get the right nuts, bolts and washers for the suspension arms as they're all crusty and I've found a couple with damaged threads.Comment
Defo shouldn't be where it is now! The other grommet seems the obvious place.
Ultra performance do very nice zinc bolts at a reasonable price. Audi also still stock some.
Our Audi S2 wishbone bolt set comprises high tensile Grade 10.9 bolts and all-metal Class 10 prevailing torque flanged lock nuts.Suitable for S2/RS2 front wishbones and S2 coupe rear wishbones Supplied as an axle set of 4 x bolts & 4 x nutsReplaces N 90489301Tightening torque - 40nm + 180degM10 x 1.5mmHigh tensile Grade 10.9Organic zinc coating meeting VW-13750 standard, offering excellent corrosion resistance and low coefficient of friction for consistent torque application.Nothelle S2 Avant
Thank guys.
Not much of an update but I've started refitting some of the engine bay bits. Not in any particular order but in a way I think needs to be in before the engine goes back in.
Does anyone know which side of the brake lines the wiring loom goes?
IMG20240611140307.jpg image widComment
There are some pics at post 174 on my thread which may help.
