My silver RS2 Project
  • johne
    • Apr 2007
    • 1405
    Just unplug the single wire connector on the top of the compressor, that's the feed for the clutch and you can be sure the compressor won't engage. Can run that way forever without any damage if you choose.
      • Dec 2017
      • 5987
      Brilliant, thanks
        • Dec 2017
        • 5987
        Radiator has gone back in. I had to re make the connection on the fan as someone had cut the wire.
        Next job is to clean up and re paint the slam panel.
          • Dec 2017
          • 5987
          I fired up the garage heater and a few parts got some zinc primer.
            • Dec 2017
            • 5987
            I'm wanted to drain any dregs out of the petrol tank.
            The petrol is very yellow and smells old.
            I got nearly two gallons out!
            The air filter housing got a good clean and then fitted. I put a new filter in. The K&N inside had seen better days.
            Then I put some cheap oil in ready for first start. This will just be the flush oil, used for only 10 minutes or so after the first start to flush out all the assembly lube etc.
            And some new mineral oil for the hydraulic system.
            Still lots to do but getting there slowly.
            • Nuvo
              • Nov 2003
              • 3825
              #231
              Hi Dave, are you sure you're okay using G 004 000 M hydralic fluid? This is synthetic instead of mineral based oil, the dealer advised me not to mix the two types.
              I'm sure you've probably done your research, but I thought I'd best ask just in case it was an oversight.
              edit: According to this page all should be well.
                • Dec 2017
                • 5987
                The system is empty so I'm not mixing. The G004 stuff replaced the G002 stuff a few years back. You are correct that the new stuff is now synthetic but its still suitable (and designed) for use in our cars and the seals they use.
                • le mans
                  • Nov 2013
                  • 165
                  • Country: New Zealand
                  #233
                  First start will be exciting. Watching with interest!
                  • K Simmonds
                    • Dec 2007
                    • 7627
                    Best place for that K&N is the bin, dreadful things. A good quality OE paper filter is much better job.
                    You must be close to the first start!
                    1990 B3 2.0 80 quattro.
                    1992 C4 2.8 Avant quattro
                    1994 MTM RS2.
                    1998 B5 TDI quattro Sport.
                    2000 B5 TQS.
                    • Ian Simmonds
                      • Jun 2005
                      • 2858
                      Totally agree… MAF killers.
                      93 MTMS2 Avant
                      • K Simmonds
                        • Dec 2007
                        • 7627
                        Indeed, K&N, Destroyer of MAF's and in the case of cone filter cause of unwanted noise. How they stay in business is a mystery to me. A company like Audi probably spent well over 100,000 Euro's designing a really good air intake and air-box for the S2/RS2 only to have their work sabotaged by a £50 rip off beloved by Chav's.
                        Rant over... As i approach 50 the grumpier I get.
                        Am really impressed with the great progress Dave.
                        1994 MTM RS2.
                        2000 B5 TQS.
                          • Dec 2017
                          • 5987
                          Huston we have a problem.
                          There was a small patch of oil under the car this morning.
                          I cleaned everything up and identified it coming from around here.
                          It appears to be the oil pump seal. It's the only seal I didn't spray with hylomar gasket sealer as I was worried it would enter the oil pump. The gasket is a paper one and brand new (Rinz). Getting this apart now will be a major headache.
                          I I cleaned everything up really well and re checked all the bolts (I could reach). They were all tight. So, taking a chance I went slightly over the recommended torque for each bolt. This seems to have done the trick and it's been dry all afternoon. Hopefully it will still be dry tomorrow.
                          I wonder if my little torque wrench needs calibration? The little bolts are only 10nm and if it's over reading they may not have been tight enough?
                          • andyg plym
                            • Nov 2006
                            • 4646
                            what??? First I’ve heard of this… would make sense though as I’ve been through a few mafs now. Every days a school day I guess, think I know what my next purchase is going to be now
                            • K Simmonds
                              • Dec 2007
                              • 7627
                              What make is your small torque wrench mate, and is it digital? As I said in my WhatsApp message I always tend to pinch up M6 fasters to 12nm using a Snapon digital wrench as 10nm is basically hand tight, I'll even go as far as 15nm if it stops a leak.
                              The other thing to watch out for is making sure you hold the torque wrench where it's designed to be gripped, holding it anywhere else will give false readings. I can explain why, but don't feel the need to.
                              And for others reading this, if you're afraid of using RTV sealant etc on a gasket a light smear of grease on either the gasket or the mating surface will act as a sealant and is soluble in oil, plus it holds the gasket in place which helps prevent damage whilst fitting. And you can even reuse the gasket if your in a pinch for time or begrudge purchasing another one.
                              I do a lot of fasteners just using my right arm as my torque wrench, it's pretty well calibrated now after 30+ years of spannering. My left arm is still a mess though I'm going to have surgery later this year to sort it out.
                              Fingers crossed nipping those bolts sorts it out for you Dave.
                              1994 MTM RS2.
                              2000 B5 TQS.
                                • Dec 2017
                                • 5987
                                I have a full set of Teng. For 10nm I use the smallest (5nm to 25nm).
                                i will do some testing tomorrow using another to see how consistent they are.
