My 3B Coupe Project
This topic is closed.
91 S2 coupé - RIP
98 S8 - Luxury bargeComment
Started fitting the inlet manifold to the current engine today. I want to make sure all the pipework from the IC is sorted before the new engine goes in.
Got the old one off and tried to fit the new one but it was catching at 3 places on the PAS pump.
So i dug out the old grinder and fixed the problem.
P.s. the bolt on the pump still undoes, even though its missing several mm of the top.Last edited by s2_bo; 30 January 2008, 20:33.91 S2 coupé - RIP
IM in place:
Next i need to work out how to extend the cables that are normally connected to the Throtle body and IM as they are way to short to reach all the way to the front of the engine bay.
91 S2 coupé - RIP
Picked up the Crank, Flywheel, Rods, Pistons, Shells, Pulley etc. from Basset Down Balancing today.
It all looks in order, so its almost ready for rebuilding.
IMG_0208.jpg91 S2 coupé - RIP
About time too Bo. Nice clean flywheel you have there.
My IM cleared the hydraulic pump fine, but the belt will need changing more often. There's not much room for adjustment for a loose belt.SSComment
Its an OEM one, even the original from the car when it was first assembled. Its just been shoot blasted
I doubt this will even touch yours mate, im only going for rs2 spec after all. So mine will me ponies compared to your warhorse..
91 S2 coupé - RIP
Lol, it is?
What does the writing say on it? I can see "not" though.
Well, we have to find out someday then? :mischeif:
Lets say.... on a track a little far far away, but not too far, maybe something with a laptime around 9 ish minutes and located in a country the brand was born in?
Anders - S2 Avant Clubsport - 8pots or die!
Tis on!Lol, it is?
p.s. writing say's that they are not lock tighted yet. - referring to the 4 bolts.91 S2 coupé - RIP
You 3B boys, Wagner sells a new PAS bracket for the ABY which lowers the pump 15mm
thanks for that mate..
