My 3B Coupe Project
This topic is closed.
  • philS2
    • 356
    Originally posted by s2_bo
    No, but Stu slaved away on them for hours with a bead blaster.. thanks for that mate..
    have you leak tested them mate?
    • s2_bo
      • Oct 2005
      • 6067
      #137
      They were all individually reseated so the seal "should" be spot on and should not leak.
      91 S2 coupé - RIP
      98 S8 - Luxury barge
      • AndersS2
        • 1364
        • Home: Norway
        #138
        What kind of lifters and springs did you go for?
        Did you also change the seat by yourself?
        looking good
        Anders - S2 Avant Clubsport - 8pots or die!
        • s2_bo
          • Oct 2005
          • 6067
          #139
          looking good
          All stock 3b Anders, im not aiming for mega RPM peaks so i think they will do.
          I had the seats done by my local engine shop.
          Cheers.
          Bo
          91 S2 coupé - RIP
          • AndersS2
            • 1364
            • Home: Norway
            #140
            ok,
            it does make sense then.
            Have to say you do a good job about the rebuild. it'll be good to see her on the road again.
            btw, nice homepage
            • s2_bo
              • Oct 2005
              • 6067
              #141
              Started fitting the inlet manifold to the current engine today. I want to make sure all the pipework from the IC is sorted before the new engine goes in.
              Got the old one off and tried to fit the new one but it was catching at 3 places on the PAS pump.
              So i dug out the old grinder and fixed the problem.
              P.s. the bolt on the pump still undoes, even though its missing several mm of the top.
              91 S2 coupé - RIP
              • s2_bo
                • Oct 2005
                • 6067
                #142
                IM in place:
                Next i need to work out how to extend the cables that are normally connected to the Throtle body and IM as they are way to short to reach all the way to the front of the engine bay.
                91 S2 coupé - RIP
                • s2_bo
                  • Oct 2005
                  • 6067
                  #143
                  Picked up the Crank, Flywheel, Rods, Pistons, Shells, Pulley etc. from Basset Down Balancing today.
                  It all looks in order, so its almost ready for rebuilding.
                  91 S2 coupé - RIP
                  • 4WheelDrifter
                    • Oct 2004
                    • 5773
                    • Country: Devon
                    #144
                    About time too Bo. Nice clean flywheel you have there.
                    My IM cleared the hydraulic pump fine, but the belt will need changing more often. There's not much room for adjustment for a loose belt.
                    SS
                    • AndersS2
                      • 1364
                      • Home: Norway
                      #145
                      Bo, where did you get that pulley from and what difference is it compared with the oem one?
                      Ps, this s2 of yours is going to let mine taste dirt as h€ll
                      cheers,
                      • s2_bo
                        • Oct 2005
                        • 6067
                        #146
                        cheers,
                        Its an OEM one, even the original from the car when it was first assembled. Its just been shoot blasted
                        I doubt this will even touch yours mate, im only going for rs2 spec after all. So mine will me ponies compared to your warhorse..
                        91 S2 coupé - RIP
                        • AndersS2
                          • 1364
                          • Home: Norway
                          #147
                          Lol, it is?
                          What does the writing say on it? I can see "not" though.
                          Well, we have to find out someday then? :mischeif:
                          Lets say.... on a track a little far far away, but not too far, maybe something with a laptime around 9 ish minutes and located in a country the brand was born in?
                          • s2_bo
                            • Oct 2005
                            • 6067
                            #148
                            Lol, it is?
                            Tis on!
                            p.s. writing say's that they are not lock tighted yet. - referring to the 4 bolts.
                            91 S2 coupé - RIP
                              You 3B boys, Wagner sells a new PAS bracket for the ABY which lowers the pump 15mm
                              • volcano rs
                                • Jun 2005
                                • 2265
                                we shortened the bracket on sals car and it fitted perfect .
