Filter housing with oil thermstat built in. No need for the spirol pins but you keep the old stubby thread the filter normlly goes on. The housing is attached with a new part with a duplicate thread for the filter.
Can't help but notice that you seem to be doing all this work in the middle of your lounge floor or is your garage carpetted??!!
Good luck with build it seems to be progressing well. Looking forward to the finished result. Which car is it going into?!!
1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
Based on the 7A NA 5 cylinder block with components sourced from the 3B/ABY/AAN/ADU engines.
Parts. Part No.
Short block. 7A
*Crank 92.8mm.
Scat con rods 144mm with 20mm pins. 2-5670-1992-981-787S
*Wössner pistons, 83.0mm K9505D050
Main bearings, Glyco. H981/6 STD
Main thrust bearings, Glyco. A124/4 STD
Big end bearings, Glyco. 71-3694/5 STD
Main bearing cap bolts, Grade 12.9. M10X1.5 80MM long cap head
Main cap washers, 12 off. ARP 200-8681
Thanks very much for posting a parts list. It'll be a little while before I start doing any thing with my engine as first I need to work out exactly what i'm going to do. Hope to start later this year
cheers
mike
Don't think it's a Mocal...no name on it. Plenty around from the usual places, 'bout £20.
That large bolt for the s2 housing were damn expensive...
If thats the thermostat I gave you it is a Mocal one, it had a new seal fitted 2 years ago and bought direct from Mocal along with 19 row cooler (bit of an overkill as it turned out) when I had my tuned KV in the engine bay.
I'm using the 7A block to help with the increase in bore size to get me to 2.5lt (92.8mm crank), using the 3b/aby would mean having the bores machined several times and therefore more £'s per bore cut.
Carlos.
