Project: Engine Build for beginners.
  • Flat on my back
    • Jan 2007
    • 2449
    Preliminary coil bracket design.
    Here...
    Carlos.
    • Flat on my back
      • Jan 2007
      • 2449
      Parts list.
      On here...
      Carlos.
      • Mr.Crossfire
        • 145
        Where is the 92.8 crank from? Is it a std vag-part or aftermarket?
        • Flat on my back
          • Jan 2007
          • 2449
          VAG part...
          Supplied by...
          C and R Enterprises.
          Nottingham.
          UK
          With over 20 years experience C&R Enterprises supply high quality specialist parts and servicing for your Audi, Seat, Skoda or Volkswagen.
          Carlos.
          • Mr.Crossfire
            • 145
            I meant which engine is it from, originally? Or do you have vag part number for it?
            • Flat on my back
              • Jan 2007
              • 2449
              Shamelessly stolen from the Audifans.net site.
              There is an obscure crank from an 'industrial' engine with the 92.8mm stroke, you could use this with 3A or 6A pistons to get your 10v/20v up to 2.5L. If you used the tdi 2.5 crank which is 95.5mm stroke you end up with approx 2.6L but need custom pistons. Either crank could could be used in the shortdeck block, but the crankcase area needs opening out to clear the longer 'throw' of the crank.
              Either could be used in the talldeck tdi block (which presents its own obstacles) You would use VW ABF/2E conrods, again pistons would need to be modified/custom with the 95.5mm crank
              034 105 101 J = 92.8mm stroke
              074 105 101 = 95.5mm stroke
              Thanks 'scotty33'
              Good luck hunting...
              Carlos.
              • auditude
                • 407
                92.8mm crank
                Originally posted by Flat on my back
                There is an obscure crank from an 'industrial' engine with the 92.8mm stroke...<snip>...Good luck hunting...
                Not as obscure these days:
                Kenneth
                1990 Coupe quattro
                1991 200q20v x 2
                1985 4ksq 20vt project
                1986 Coupe GT 10vt project
                2006 Honda Ridgeline
                1998 Honda VFR800FI
                  Originally posted by auditude
                  Except it's based in USA and candrenterprises are based in the U.K
                  • Mr.Crossfire
                    • 145
                    OK. Thanks for the info. I am currently building my engine with shortdeck block & std 86.4 stroke, but maybe some other engine will be more special.
                    • auditude
                      • 407
                      So becoming even less obscure with each post.
                      Kenneth
                      1990 Coupe quattro
                      1991 200q20v x 2
                      1998 Honda VFR800FI
                      • Flat on my back
                        • Jan 2007
                        • 2449
                        LS2 coil bracket and supports.
                        Finally got the last pieces for the coil bracket...thanks Andy for all the info on your bracket...darn shame the dims didn't match up...
                        Now just need to find a suitable place to fix it and hope the 7A leads are long enough.
                        Carlos.
                        • terrybullwon
                          • Mar 2006
                          • 8782
                          Good idea Carl,
                          More technical than my aproach of this
                          And then i machined down one spacer and added a 6mm bar to the strut brace
                          Chef
                          • terrybullwon
                            • Mar 2006
                            • 8782
                            vala
                            Chef
                            • Flat on my back
                              • Jan 2007
                              • 2449
                              Due to the economic downturn...
                              this project is now on hold...
                              Now looking for a new job...
                              Carlos.
                                Sorry to hear this
