Machine Head Project
    that is handy
    excellent picture Mark - good find
    Amazing how close the stud threads are to the face
      #47
      Originally posted by mcandmar
      Paul, incase you missed it this was just posted in another thread...
      Found this little gem
      A *MIGHTY* find there Mark - hadn't scene that one. Need to translate and digest it now, but by looks of things that guy has gone a bit too shiny on the inlets and sharpened that separator blade - I won't be doing that.
      The EX ports need to be super shiny of course.
      That cutaway pic is a lifesaver
      I've had conflicting opinions on the cam bearing BTW - some say it would be weldable (with care), some say neigh and others say the bearing takes so little load that it will be fine - the crack doesn't go all the way thru.
      I had another idea... To use that mental metal filler called 'JB Weld' as that should allow me to fill the crack to redrill the stud hole and make it look a lot tidier.
      I'm horrified at the list price of valves and valve guides. None of the valve guides are worn or scored, so I'm very tempted to just leave them be... Except they will get in the way of the porting work. Dangit.
      Its shocking how expensive this build up is going to be with a fresh set of valves, lifters and guides, plus the coilpacks, hall sender etc. I'll check all the springs for sanity but can't see a need to renew them at the moment.
      Paul
      • 4WheelDrifter
        • Oct 2004
        • 5773
        • Country: Devon
        #48
        Paul. I was also shocked by the price of new valve guides from VAG. As much as I hate to use anything but original parts, especially from GSF, I ended up getting my valve guides from them.
        The P/N is 14487, they are the same as MkII Golf 16V VGs as you'd expect.
        Hopefuly they'll last more than 6 months like GSF bearings and bushes seem to.
        SS
        • mcandmar
          • Apr 2004
          • 5118
          I got Febi valve guides from Vagparts, they were £14 each for the Audi part, and £1.70 each for the Febi. Do the math for 20 if you want a shock!
          Good point on the cam bearing, i wouldn’t have thought the load would be very much being at the end. Having said that it also has to take the load from the chain pulling on the intake cam.
          I guess the real question is what condition is the bottom of that bearing cap like? If it hasn’t been damaged and sits true with the head i don’t see why it wouldn’t be fixable
          Mark.
          91CQ20v - Gone to a new home
          93UR-S4 - The Magic Carpet
          94S2Bus - The Emerald Express
            #50
            The bearing surfaces all seem fine and dandy - aint done much work this week on it - managed to slice a finger open whilst tiling a floor - that'll teach me. Oh got some pics unposted from a while back though.
              #51
              Here's a couple of valve spring compressors - the upper one is a loaner from Diesel-Des - its the proper monty with adjustability at each end. The lower one is my old one bodged with a socket to give it the right reach for disassembly - it will not work for the rebuild.
                #52
                When I was playing with the dremel and some attachments I wanted to see what woulld be best for decoking the valves - I'm throwing these 7A EX valves away as they arent sodium filled. I was surprised how easy it was to remove too much material on the valve surface with an ordinary dremel grinding stone...
                I need to get a proper set of head-porting stones / widgets before I go anywhere near the head.
                The steel wire brush was great for removing coke but I fear its going to be too harsh on the alloy head - maybe need some sort of brass bristles to do less damage.
                • Flat on my back
                  • Jan 2007
                  • 2449
                  Coke removal?
                  I'll be trying acid based wheel cleaner or oven cleaner.
                  Wouldn't advise using a steel brush anywhere on the internals, it will leave small particles embedded in the alloy.
                  Carlos.
                    If you buy one of the cheapo Dremel accessory packs off ebay, the wire brushes that come with them are brass not steel
                    • Flat on my back
                      • Jan 2007
                      • 2449
                      If money no object...
                      These are what you really need to do the job proper like.
                      Carbide rotary burr set,1/4 head
                      RS Stock no. 157-2893
                      Manufacturer Garryson
                      Manufact. part no. RSBKIT3 S
                      1+ £108.75
                      Carlos.
                        soooo much cheaper in the states, who'd have guessed it
                        http://www.carbidebur.com/bursmain.html
                        Also good for equine dentistry apparently - that horse pic had me in stitches
                        • Mark Halligan
                          • 2001
                          @Paul
                          I am a dog......I just noticed that template for the water manifold conversion all packaged up to send to you - rolling around in the back of my car tonight.
                          Sorry mate, I WILL post it to you this week.
                          Mark - Modded
                            #58
                            Aye - you are one big hairy dog alright - with a deep shiny coat, a collar full of bling and a bite to match its bark with the stuff you've been up to on that animal of yours
                            No sweat on that template - I just figured you hadn't posted until the strike backlog had calmed down. Its not like I'm in a desperate rush for this job. This weekor next is grand.
                            I'm going shopping for a kit of head porting stones next - any recommendations ?
                            Paul
                            • Flat on my back
                              • Jan 2007
                              • 2449
                              Hmmmmm...
                              That gets me thinking, gf is well into horesey stuff. Will find out if its cheaper in the equine market?
                              Carlos.
                                i thought that might be a good excuse for you to invest Carl
                                So have you planned the actual porting yet Paul? What is going to be the plan for machining the ports etc? Any idea in the extent you will go to?
