Machine Head Project
    #76
    Heres the water rail template.
      #77
      And another with it resting more or less in place... I've marked the new hole locations required. Shows 4 here but got a notion that one is already there.
      • s2_bo
        • Oct 2005
        • 6067
        #78
        Thanks for that pick Paul. Its good to know what machining would be required to convert a 7a to s2 spec.
        It doest look to hard.
        Good luck
        91 S2 coupé - RIP
        98 S8 - Luxury barge
          #79
          The bit needing most accuracy is the new studs for the water rail... This template is perfect for lining up where the waterways need drilled in the head, but I think I'll partially bolt down a water rail to get better accuracy on the new stud holes.
          I'll prolly go to a local machine shop for this bit - I don't even have a bench drill... And its umpteen years since I used a tap and die set to create the new stud threads !
          • 4WheelDrifter
            • Oct 2004
            • 5773
            • Country: Devon
            #80
            That looks like a handy tool Mark. I've not had any workshop time to make my template yet.
            SS
            • Mark Halligan
              • 2001
              Its not, bolt the plate to the head via the existing threaded holes on the plate to align it.
              You need a 19.5mm drill bit for the water ports and a 5mm bit for the bolt holes (~16m deep), and then these are tapped with an M6 tap. Drilling was done using a cheap old bench drill.
              Bit of time and care = perfect fit
              Mark - Modded
              • Mark Halligan
                • 2001
                By the way if you want to clean any carbon off of the head or out of the ports before getting in there with a burr or cartridge roll.
                I've said it before......................Fairy Power Spray LOL
                Mark - Modded
                • audiman
                  • 4827
                  Paul just a note on those metal washers under the VSOS. I have built a few heads up now and noticed that they arent always fitted as the album suggests. I have seen 7A's with inlets only and also some ABY's with inlets only. Yet my 3B had all of them, and IIRC so did Ross's 3B head. They are just a hardened steel washer that prevents the valve spring seat "hammering" into the alloy. Fit all 20 IMO.
                  I also used GSF valve guides in my head, only needed to change the ex. ones as the inlets had virtually no wear.
                  @Stu, rememeber i said i thought i had a load?? I found them in the workshop this week!! I have a spare set of 9 valve guides and 2 piston rings sets LOL
                  Tom C - www.rcmr.co.uk
                  Audi UR Quattro
                  Audi 100 C3 2.0 5 cyl 115ps
                  Audi B5 RS4 645ps 911nm
                  • audiman
                    • 4827
                    BBQ cleaner also works very well
                    Audi UR Quattro
                    • 4WheelDrifter
                      • Oct 2004
                      • 5773
                      • Country: Devon
                      #85
                      Too late.
                      @ Paul
                      I also recommend a pair of marigolds and a toothbrush to go with that.
                      SS
                      • terrybullwon
                        • Mar 2006
                        • 8782
                        Originally posted by 4WheelDrifter
                        Too late.
                        @ Paul
                        (Shakes Head)
                        Very corrosive, we use this in the kitchen and its eating our aluminium pans
                        Chef
                        • 4WheelDrifter
                          • Oct 2004
                          • 5773
                          • Country: Devon
                          #87
                          Originally posted by terrybullwon
                          (Shakes Head)
                          Yeah. I don't doubt it. It's evil stuff and wouldn't recommend cleaning your cylinder every week with it, hence the need for marigolds. Breathing apparatus might be a good idea too in a confined place. I can't believe it's made for use in the kitchen really.
                          SS
                          • terrybullwon
                            • Mar 2006
                            • 8782
                            Bit mad eh
                            I bet it does a bloody good job, i have used a solution as mark said of fairy and water this too is also alittle savage
                            Chef
                            • Flat on my back
                              • Jan 2007
                              • 2449
                              Now confused...
                              They are actually marked 027 611D which misses the middle three digits from the part number - I need 027 109 611B of course...
                              Just looked at the ones from my 7A head and they are 'non sodium' . Thought the 7A had them fitted?...or so my Bentley says?
                              So which engine did get them, 3B, ABY, ADU...etc?
                              Thanks.
                              Carlos.
                              • audiman
                                • 4827
                                turbo heads had the sodium valves
                                Audi UR Quattro
