Dutch circuit S2 3B
  • Evert Thomas
    • Sep 2007
    • 178
    Dutch circuit S2 3B
    Dear forum people,
    I have been on this forum for a while, so it is time to introduce you my project. Let me first introduce myself. My name is Evert, 28 years young and living in the north of the Netherlands.
    This year in may I have bought an red Audi Coupe S2 from 1991, wich has run 260K. My intentions with the car is to make is suitable for the circuit. Not attending to do competions, but yust for fun, manly on the Nordschleife in Germany. I have choosens for the S2, because i wanted to be an Audi, and i like the Quatro technique.
  • Evert Thomas
    • Sep 2007
    • 178
    First step of the project was, to make the car safe for using it on the circuit. Well known problem of the S2 are the brakes, these are actually too small for the car. The solution is as also well known, Porsche RS2 Brakes. So this was the first thing to do. So I ordered the S2 Porsche Brakes, National grooved 320mm front brake disc, Ferrodo Racing 2500 brake pads and stainless brake hoses.
    • Evert Thomas
      • Sep 2007
      • 178
      Second step was the suspension. We find out that the suspension as it was under the car, wasn't that good anymore. Friends of me are using adjustable suspension from KW Mark III under their car, and they are ferry pleased with it. Unfortunaly KW Mark III is not available for the S2, so I have chosen for the Mark II.
      • Evert Thomas
        • Sep 2007
        • 178
        Using the Porsche braking, brings I couldn’t use the normal rims. So I have to look for new rims. This wasn’t too easy because a lot of rims don’t fit. But fortunate I managed to finds some new rims. These are Oxigin 17 inch 7,5j.
        • Bram
          • Aug 2006
          • 2582
          From that 2nd and 3rd picture it looks like you did not install the steel brake lines? Or did you only change the outside brake lines?
          • Evert Thomas
            • Sep 2007
            • 178
            Using new rims also means you have too get new tyres. Because I wanted to use it on the circuit I have chosen for the Falken Azemis 612 225/34 17.
            • Evert Thomas
              • Sep 2007
              • 178
              Yess, is installed, but after the picture was taken.
              • Evert Thomas
                • Sep 2007
                • 178
                The seats of the S2 are nice, but not good enough for the circuit in my opinion so I bought two Sparco racing seats
                • Evert Thomas
                  • Sep 2007
                  • 178
                  Last step of this phase was getting rid of some overweight
                  • s2driveruk
                    • 12696
                    bet that has saved a few lbs in weight?
                    Looking good
                    1992 3b S2 Coupe
                    • Evert Thomas
                      • Sep 2007
                      • 178
                      After done that it was time to do something about the exhaust. The one which was under the car was not the fresh anymore. So I decide to replace the entire exhaust for a 3 inch stainless steel one, with an Simons silencer. I also removed the two catalyst.
                      • Evert Thomas
                        • Sep 2007
                        • 178
                        Yes, but I don't know how much, because I didn’t weight the materials which came out. There will be some weight back in, because of a roll cage.
                        • Evert Thomas
                          • Sep 2007
                          • 178
                          For this winter we have the next things will be done:
                          Exterior:
                          - RS Rieger front bumper
                          - Rieger rear bumper
                          - Rieger side skirts
                          - Air outlet on the bonnet
                          - Kamei grill
                          - Rieger EVO Wing
                          - Unrolling the wheel guards
                          - Complete paintjob of the car in a two tone colour. Metalic grey with metallic Bordeaux red.
                          Engine
                          - New engine block (because the old one is I little gap in it).
                          - Revision of the engine block
                          - New turbo Garret GT3071R
                          - Bigger intercooler from 034 motorsports
                          - High flow exhaust manifold from 034 motorsports
                          - High inlet manifold from 034 motorsports
                          - New connecting rods, which brand not certain yet.
                          - New JE Pistons
                          - New Camshaft, wich one’s I don’t know yet.
                          - New clutch, I think it will be a Sachs.
                          - New fuel pump.
                          - New injectors
                          • Evert Thomas
                            • Sep 2007
                            • 178
                            The next colour scheme will be used
                            • Evert Thomas
                              • Sep 2007
                              • 178
                              It has been A wheel I post on this item, so let me update you about the progress. First the parts I have recieved:
                              1. Inlet manifold
                              2. JE pistons
                              3. Exhaust manifold
                              4. Turbo Garret GT3071R
                              5. Spec clutch
                              6. Intercooler
                              7. Engine brackets
                              8. Connection rods
                              9. Downpipe
                              10. Tial blow-off valve
