Dutch circuit S2 3B
  • Audi_CQ
    • 940
    • Country: Norway
    #76
    Originally posted by Evert Thomas
    With regard to the wastgate the frequency valve is for now the main problem. With the DTA stand alone computer it is hard to find the righ frequency. We have found a frequency valve for which the frequency to use with the DTA computer is known, so I hope this will be te solution.
    I'm running a DTA S100 with an Autronic valve. Regulate on top with a frequency of ~30hz. Running with base turbo map only(no PID) so I can have different boost pressure depending on TPS.
    • Evert Thomas
      • Sep 2007
      • 178
      Last week we recieved the powdercoated control arm, and this weekend mounthed them to the car.
      New control arms
      The old control arms removed
      New tyers on the rims
      Compare them with the old toyo tyers
      The control arms mounthed
      Take a look how it goes
      And also with the new tyers
      • terrybullwon
        • Mar 2006
        • 8782
        your arb is missing
        Chef
        • Evert Thomas
          • Sep 2007
          • 178
          That is correct. It's removed because the whole subframe was removed. For the ARB at the back we are waiting for the new one.
          • Bart76
            • Apr 2007
            • 117
            Nice Evert!!
            Wat doe je met de oude banden??
            • Evert Thomas
              • Sep 2007
              • 178
              Nog niet over nagedacht, intresse?
              • Bart76
                • Apr 2007
                • 117
                18 inch toch? hoever versleten? prijs?
                • Evert Thomas
                  • Sep 2007
                  • 178
                  The new camberplates in progress
                  Made a start with the reconstruction of the front of the car and the engine bay
                  • Evert Thomas
                    • Sep 2007
                    • 178
                    The camber plates getting it's shape, some pictures
                    Front of the car removed, and removed everything in the engine bay what isn't needed anymore
                    • Evert Thomas
                      • Sep 2007
                      • 178
                      New pulley for the alternator in progress
                      • Evert Thomas
                        • Sep 2007
                        • 178
                        To get the car ready in time for the first Time Attack Event, we decide to work also on the car at the second christmasday. An update
                        The topmounths in progress
                        Tidying op the wiring in the enginebay
                        Got rid of about 5kg of the crank pulley, so also the radiator will fit more easy
                        • Evert Thomas
                          • Sep 2007
                          • 178
                          Just before the year will end a update of the work done last week
                          Painted the steering rods
                          We turned off the half of the crankshaft puly, to make it lighter and to create space for the radiator. Also the new steering pump puly installed.
                          The new alternator in place (lighter with a higer voltage). We placed the alternator a bit more backwards and the puly we made ourself. The pullies will be driven by just one v-belt
                          New intercooler
                          The new radiator will look like this and will be one of a Subaru Impreza
                          Frame in progress for the frontside of the car
                          Fitting the intercooler
                          The new bumper. It's clear al lot of cutting have to be done.
                          Tomorow another day!
                          • quattro84
                            • Mar 2006
                            • 947
                            What altenator are you going to use now Evert?
                            • Evert Thomas
                              • Sep 2007
                              • 178
                              It's an second hand alternator, I think of a VW Golf. It's a Boch alternator and delivers 14 volts and 70 ampere.
                              • terrybullwon
                                • Mar 2006
                                • 8782
                                you shaved off all the weight of the harmonic crank balancing pulley why?
                                Chef
