Dutch circuit S2 3B
  • Evert Thomas
    • Sep 2007
    • 178
    Originally posted by terrybullwon
    you shaved off all the weight of the harmonic crank balancing pulley why?
    The main reason is that otherwise the radiator won't fit in front of the car. Another advantage is that we loose some weight this way. We don't believe that loosing the weight will have a mayor effect on crankshaft.
    • Evert Thomas
      • Sep 2007
      • 178
      It has been quiet for a while, not because we didn't do anything, but because we were very bussy, so what did we do.
      Slowly we getting to are end goal, we finished the chassis, and we decided what kind of suspension we are going to use, this will be 'hardware' of H&R, dampers/inserts of AST en springs of Eibach. But the build of it will take some more time than expected, so we changed are plan a bit and we will start with the bodywork now.
      The new radiator is in its place, it is a radiator of a Subaru Impreza, and ofcourse we had te make some adjustments to make it work for us, with many thanks to Veenstra's Equipment.
      We rebuild the frames of the chairs, because these were still on rails (because of Dutch MOT, which had changed now)
      Fuly new inlet tubing, and a bit bigger.
      • Evert Thomas
        • Sep 2007
        • 178
        Some pictures, no stories this time, just look at the differences!
        All decals removed.
        • TimE-J
          • Jul 2009
          • 1292
          Good progress!
          96 S2 aby Coupe. Rebuild Project
          96 mk3 golf tdi daily.
          • Evert Thomas
            • Sep 2007
            • 178
            Het Esrij Tuning Audi S2 Time Attack Team en Veenstra's Equipment spend their weekend in garage and not on the ice. Althought there fel some snow in the garage (well sort of).
            Tearing the parts off
            Cleanded that tank plate
            After braking you can start building
            Man at work
            DTM Style
            Tomorow the project continues
            • Rocco
              • Aug 2007
              • 6393
              • Country: Spain
              #96
              Hello!
              Could you tell me why you do use wide clamps with the silicon hoses?
              I have slim and wide ones but one forum member told me that the slim ones are better to torque + 2bar of boost....because they are able to push more pressure in the same space....
              Is this correct?
              I want to learn
              Thanks!
              • Evert Thomas
                • Sep 2007
                • 178
                i don't know how it will work, my turbo is generating about 1,4 bar that is far less thent 2,0 bar.
                • Evert Thomas
                  • Sep 2007
                  • 178
                  The work of today
                  • Bram
                    • Aug 2006
                    • 2582
                    Do you really need that much extra width to get the car stable for some time-attack races?
                    • Evert Thomas
                      • Sep 2007
                      • 178
                      Well the car is not even that much wider, about 2,5cm each side. We believe that the extra width and lowering the car will result in more grip. The fenders are even widered more, because we wand to put the tyers out of the wind.
                      • Evert Thomas
                        • Sep 2007
                        • 178
                        Done some more work at the body of the car
                        Making a tunnel for the oilcooler
                        • AndyP
                          • 6049
                          Are you planning on coming to the UK again this year?
                          • Evert Thomas
                            • Sep 2007
                            • 178
                            Yes 5th of may on Cadwell Park, for the Time Attack round 1
                            • AndyP
                              • 6049
                              Great, I'm going to try and get to this one this year, missed you last year
                              • Evert Thomas
                                • Sep 2007
                                • 178
                                Another small update
                                Sideskirts in progress
                                Spacers for the driveshafts
