Project "Sooty"
  • Ryan80
    • Jan 2008
    • 154
    • Home: Northern Ireland Current: United Kingdom
    #406
    So i had posted on this topic way back at the start, it was getting impressive then, but now its awesome! and i salute you for helping my homework for the five stud conversion, i just need to gather the bits!:mischeif:
    I was getting bored with my dagdag, and had planned to buy a 2002 a6 tdi avant, but i think im now going to keep it, and do the five stud conversion, find some nice bbs split rims, and try and tune it a little.
    so again, hats off to you sir, and keep enjoying the car!!
    Time waits for no man. Unless that man is Chuck Norris.
    • Jas11n
      • 5067
      Thanks Ryan,
      Managed to get the ATD installed.
      Same procedure as documented >>> here apart from I routed the sensor wire through the passenger side bulkhead instead, just because I have a few cables going through there anyway.
      Thanks to Paulgo for the sensor and the black connector. All came together nicely as I originally planned to use another connector. Reason being, after vagparts have gone, it's a 50 mile round trip to a dealers. Hardly worth it for a £1.40 part. I was going to use one of these instead;
      But Paul had a connector spare and I luckily had 5 female pins with wires left over from the grab handle light install in the S2.
      Sorted.
      Sensor located behind the nearside bumper grille. Secured to the cross member mounting plate:
      New connector receiving it's pins/wiring:
      Fired up before fitting to cluster:
      Random:
      Original bulb :
      2001 Avus Silver B5 RS4.
      1995 S2 Coupe - sold (sniff)
      • StompOn
        • Jul 2009
        • 67
        when ya did the fog lights was the plug for the switch in the dash after? as im doing the s2 front bumper on mine very soon just done the vdo gauges must say im very impressed gives real insperation to keep these dagdags going
        The Power Of A DagDag
        • Jas11n
          • 5067
          No, the wiring and plug were not behind the dash. It only had the connectors for the rear of the fogs and associated wiring up to the fuse box. I got a connector from a scrappy and wired the whole lot up using a 40 amp relay direct from the battery.
          • StompOn
            • Jul 2009
            • 67
            ahh right ok tidy job will save me looking about for somthing thats not there
              Jase do you know where i can find the part number for the two pin version of this plug?
              I need a male and female one and struggling to find the part no.
              • Acidburn
                • 13459
                I may have one of them ill have a look.
                Yeah same with mine, there was no wiring/plug behind the blanks, I ended up soldering in a spare plug/wiring I sourced from a car being broken.
                • Jas11n
                  • 5067
                  Long overdue an update.
                  Sooty still lives, she soldiered on through the winter as my work hack and never let me down once. Even through some pretty bad snowy weather she still got me where I wanted to be everytime.
                  Although I'll still own her, she's off on loan to live with a friend of mine for a while, as she's just sitting doing nothing at the minute. Why? A new car took over a couple of months back, bought for a purpose that turned out not to be.
                  You know how it is, you buy something intending to do nothing, but that leads into starting down the modding road.
                  I'll start a new thread on the new motor.
                  • Jas11n
                    • 5067
                    deleted, error
                    • Marius
                      • Dec 2009
                      • 16
                      • Country: Lithuania
                      #415
                      Does your dashboard shows right fuel consumption?
                      • Jas11n
                        • 5067
                        No. The ECU does not have a fuel consumption output on this 93 TDi.
                        • Marius
                          • Dec 2009
                          • 16
                          #417
                          hm...
                          that's bad...
                          In one webpage, I saw german's solution, with some module (PWM or smth) witch converts signal on newer 1z (from 94y, with 202Nm)
                          • TimE-J
                            • Jul 2009
                            • 1292
                            Just read the whole thing and I think its great! id love to build something like this!
                            96 S2 aby Coupe. Rebuild Project
                            96 mk3 golf tdi daily.
                            • Jas11n
                              • 5067
                              hm...
                              that's bad...
                              Yes, for later 94>> ECU
                              • iynx
                                • 1
                                • Home: Latvia Current: Switzerland
                                #420
                                Please fix photos
