Project "Sooty"
  • Skull
    • 3506
    • Country: Slovenia
    #316
    that is the one yes, dont forget to block the EGR valve, helps much in the matter of power/torque.
    Audi Quattro WR
    • Jas11n
      • 5067
      I'm waiting for this to turn up, should do the trick nicely
      2001 Avus Silver B5 RS4.
      1995 S2 Coupe - sold (sniff)
      • Jas11n
        • 5067
        Ok, here we go.
        I had to use some extra length of silicon hose, as the supplied one wasn't long enough. So went from nipple on the inlet, down under the battery tray and through a grommet in the bulk head. That brought the hose out just behind the glovebox. Hose then joined to the supplied hose and routed up the the vents. Power for illumination went down to the feed that supplies the glovebox light.
        Pictures can explain the rest.
        Maximum boost is 1bar
        Big thanks to my other half Allie, who showed a surprising amount of dexterity getting that boost line through the bulkhead for me.
        Jase..
        • 4WheelDrifter
          • Oct 2004
          • 5773
          • Country: Devon
          #319
          Originally posted by Jas11n
          It'll spin in third now in the rain if pushed. Strange thing wheelspin when you aren't used to it
          Nice.
          Who was it that rubbished the TDI quattro idea? My Steph even struggled with a 1.2TDI in the dry.
          SS
          • Skull
            • 3506
            • Country: Slovenia
            #320
            do yourself a favour and change all the vacum hoses on the left of this pic
            there is one also going to the IC, change them all, one tiny leak and a noticeable loss of power occours.
            Audi Quattro WR
            • sdk778
              • Jul 2008
              • 147
              i have a set of coupe headlights for sale if interested, pm me.
              Pm sent
              1999 A3 1.8T Quattro Silver
              2002 A3 1.9 TDi 130 6 speed.
              2002 TT Coupe 225
              1997 A8 2.8 Sport
              www.cotswoldvehicleservices.co.uk
              • sdk778
                • Jul 2008
                • 147
                Hi Jase, ref the front bumper, how does this fit on the standard 80, i see you made some brackets to fit the original ones, when i took my front bumper off the 80 to do the cambelt all i un-done was 4 13mm M8 bolts from behind the black foglamp trim and then pulled it off the runners on the wings, i picked up the S2 bumper from Crawford today and am still a little baffled as the two bumpers appear to mount differently, am i missing simething here or am i just being a bit Australian?
                Also where did you get the bumper grills from in the end, can't seem to find any used ones about, trying to avoid Audi prices too!!! Sure you understand!!
                Sorry for the bombardment of questions.
                Si.
                2002 TT Coupe 225
                1997 A8 2.8 Sport
                • Acidburn
                  • 13459
                  try vagparts for the pieces, iirc they arn't too bad.
                  The brackets you can either search a scrappy for a coupe thats being broken or vagparts again, should not be expensive.
                  • Skull
                    • 3506
                    • Country: Slovenia
                    #324
                    new brackets, the side ones, are something like 35€ a pair at da stealah...
                    Audi Quattro WR
                    • Jas11n
                      • 5067
                      As the guys say above, the brackets are used on all Coupe bumpers (not just the S2/V6 type) S2 Coupe, S2 Avant and also Cabriolets. I only made one part of it because I couldn't find the proper bit's, lost in the house somewhere. Found them both weeks later buried in a box of bits.
                      Bumpers grilles I bought new in the end.
                      From the boys at vagparts.
                      895 853 683 B (01C) Centre grille - £25.93
                      895 853 667 E (01C) LH grille - £13.08
                      895 536 668 A (01C) RH grille - £13.08
                      Net total = £52.09
                      P&P = £6.95
                      VAT = £10.34
                      Total = £69.38.
                      • sdk778
                        • Jul 2008
                        • 147
                        Thanks gents, i will have a scout round, grill prices not as bad as i thought Jase, thanks for the part numbers, will come in handy i dare say!!
                        Off to the scrappy's first then....................
                        Many ta's all round
                        2002 TT Coupe 225
                        1997 A8 2.8 Sport
                        • Jas11n
                          • 5067
                          Many ta's all round
                          This'll make it easier.
                          What you need (number 2 through to number 6). Click the pic for a larger image.
                          Number 2 bolts to the bodywork, the bumper is offered up and number 2 slots into the boxed section you can see between the fog and indicator cutout, then number 5 is placed over the side and a bolt passed through to the captive nut on number 2.
                          Number 5 was the bit I made, as said only cos I couldn't lay my hand on the real ones at the time.
                          Oh, brackets for the front, for both sides work out at about £28 all in from a dealers, not far off what Skull says in €'s
                          • sdk778
                            • Jul 2008
                            • 147
                            That makes things a lot clearer
                            Couldn't get my head around the box section on the bumper and the two M8 holes on the front panel ..............
                            Thanks Jase
                            2002 TT Coupe 225
                            1997 A8 2.8 Sport
                            • Jas11n
                              • 5067
                              No problem mate.
                              You'll find those two large plastic brackets on your wings that the original bumper clipped/slid onto, are no longer needed as the S2 front bumper doesn't use them. Just remove them and discard.
                              The S2 bumper is held onto the wing round the side by way of two hexagonal shaped inserts that are popped into the wing and a bolt passed through the bumper. The hexangonal holes will be there for them on your wings, they'll just be empty)
                              The inserts can be bought, I didn't bother though, I just used a SS bolt and nut.
                              Here's the part number anyway, two each side needed. N 902 521 04
                              • Skull
                                • 3506
                                • Country: Slovenia
                                #330
                                jas11n: i think you are very wrong about the wing brackets. he needs S2 bumper brackets, and looks like you need them too
                                here is a pic of 2 brand new s2 bumper brackets compared to an old audi 80 bracket.
                                u see the holes for the screws?
                                Audi Quattro WR
