Project: S2 Coupe Continously upgrade
  • s2driveruk
    replied
    we're not all the same for many of us the S2 comes alive when let loose on the smooth tarmac of a track wich is a pretty good reason to up the power, tailor the setup and shed the weight
    Mine started off being what you describe but the longer I own it, the more it needs to focus on track and be compromised for the road...though the A/C stays
  • s2driveruk
    replied
    ummmm you lost me there Jamo? I know i am due some caffeine but even so......can you explain
    replied
    I like the fact that as well as bhp ypu've gone for weight reduction rather than fitting a bigger stero and electric seats.
  • s2driveruk
    replied
    whichever way you look at it....they are tidy figures
  • magarv
    replied
    Originally posted by Audi_CQ
    355 + ~30hp air resistance = ~385@wheels = ~450+ @crank I quess
    I also think that is more right, but I like to roand off downwards when it comes to "guessing" HP figures
  • Audi_CQ
    replied
    Originally posted by magarv
    I only have G-tech pro RR measurments that says 355WHP measured in 3. gear @ 1.7 bar. A wild guess: 420-430 crank HP
  • magarv
    replied
    Originally posted by Acidburn
    thanks for the reply and good to hear people are getting high hp on the dizzy. I plan on getting the following new once the engine is done and put back in:
    new cap
    correct rotor arm
    new leads
    new plugs
    and see how I get on with that. How often do you change your plugs/leads/etc?
    do you know of anyone running 500+ with nitrous on top of that? its one thing I was tempted by.
    do you have any links to the MSD Digital 6+ ignition box + MSD HVC Blaster II coil and places to buy/reviews?
    really like how low you've got your car
    Jonus is running approx 900bhp + nos in the 90Q. (The 1065bhp pull was with nitrous)
    I know one or two 3Bs also running 500+bhp on E85 wich requires a lot of ignition power.
    I have used same Magnecore 8,5mm leads last 30 000km.
    Rotor and plugs i change maybe once a season. The MSD box is quite hard on rotor, plugs etc due to the high volt output.
    MSD box: http://store.summitracing.com/partde...5&autoview=sku
    MSD coil: http://store.summitracing.com/partde...5&autoview=sku
    The MSD tech support forum is also a great place to ask ignition related questions: http://www.msdignition.com/page.aspx?id=4209
  • Acidburn
    replied
    I have no plans to change the dizzy, there are 3B's in Norway running 600bhp+ with dizzy. I have done 30 000km with this setup on stock bottom end. (inkl 50 laps @ the Ring, at least 200 laps @ rudskogen) Jonus have also dynoed 1065bhp with dizzy and used it for 3 years...
    (I am using MSD Digital 6+ ignition box + MSD HVC Blaster II coil)
    My only plan for later is to build a strong bottom end with H-beam conrods, ported head and som Skinne cams. Then I can turn up the boost a little more
    The 3B ignition is more than good enough if the setup is correct But if you are running the wrong, wide rotor, old "rotorcap" and old worn ignition cables etc, then you are in trouble when you start turning up the boost.
    new cap
    correct rotor arm
    new leads
    new plugs
  • magarv
    replied
    Originally posted by Andy_Casey
    Installed!!!
    Try it out, It is real easy to use. There are 14 tracks available to download in the UK, and you can very easily create your own around the block Just go to tracks, meny and download
  • magarv
    replied
    its been a while since i've seen this thread, only just noticed its a 3b.
    what power do you think your making and are you planning on leaving it a 3b running off the dizzy?
    replied
    Installed!!!
    replied
    That's a dudey little gadgetr for the Nokia. My N95 has GPS...
  • magarv
    replied
    1380kg is good. Are you still 5 speed? If I strip my ABY out then I'm aiming for 1400kg. Made a big difference when I did it once before.
    With less weight and more power you will be even faster round the 'ring!
    This is with 6 speed box. I realy hope to be close to 1300kg. Accelration and corner speed will definetly improve with less weight.
    I have also got new lap timing "device": nokia mobile phone with Racechrono software. (www.racechrono.com) I have done some testing and it works great! No need for performance box to take laptimes, spilttimes and cornerspeed. I have also tested out racechrono2avi software so I get speed overlay on my inboard movies
    Looking forward to check max speed @ Scwedenkreuz and Fuchsröre
    Check out the forum section on www.racechrono.com for more information, the software is free and very easy to use
  • Acidburn
    replied
  • Tom_
    replied
    I have some hires pictures. Here some examples: (I cant post them at full res but I can send them to you)
    ok send me, on email?
