some new updates,
Audi S4 small drag project
No money for dry sump, ATM so - accusump, hope it works ok, and some minor brake upgrade on front.Comment
Some more chasis updates, by Hexer.Attached Files- dd884a15.jpg (36.1 KB, 167 views)
Some new photosComment
Curious to see how it works out for you. I've spoken with Jens Eklund about his car last summer, and he said they used the hardest springs they could find.
Theoretically, longitudinal movement of the car should be killed by the dampers and not the springs.Comment
My car, is somewhat lighter than the s4, and i i saw some launches of a coupe using 1000lbs spring - , i quess the right combination, is hard to be found from first try
The rear spring rate is triple as the oem fitted on this car, as the car is considerably lighter the 70 N/mm should be ok for non treated track and DOT tire.
Yet there are fairly cheep and arrive fast...so no problem if we need harder one, also the shocks are double adjustable and can manage spring rate up to 180N/mm
The font spingtare is at the moment 50 N/mm can be changed costfree.Comment
some more pics. Again Hexer is in charge of chasis, and suspension
Some updates , and in the near future, stronger driveshaft, and maybe on piece propeller shaft, as the stock one, is to long.Comment
