Audi S4 small drag project
  • #76
    90mm, yes single rear silencer. If everything ok in the next weeks, the car receive a new settings for 1.4 bars, LC, ALS , a raised rev limiter to 8000 rpm, and a set of Hoosier drag radials. I was in the car most of time, so i did not catched on camera a full trothle third gear pull , the sound is amazing - it pulled around 0.5g at 160+ kmh (if my gtech worked right)
    • #77
      New settings, 8000 rpm limit, from graph, the car still pulled strong around 8000rpm , 1.6 bar boost. I don have a lot of experince, but i think it is a very good result. No more races this year, so i dont think i will have were to try the new settings, maybe next year will be better, an hopefully get a 10 sec run.
      • #78
        Today it was a sunny day here, after a week of raining i took the car out, and i tryed some 80-120 times in second gear with dynlicious just for curiosity.
        and i get
        1.43
        1,47
        1,66
        Next time i will try to mounte the go pro camer, on speedomtere
        • #79
          New shoes for the car.
          • #80
            Nice! DOT approval..? :mischeif:
            • #81
              Well done!! Can't whait till a run... Can I...can I???
              Goodluck!!!
              • #82
                Some updates, my tuners modified the timing, to bring the powerband a little lower in revs. I did only one race, bad 60ft, no LC, and ALS, street tyre on VHT, result
                12.2@206 kmh (i changed to 5, even if it was not needed) , 2.24 60ft. I was lined with a 700+ TDI, dont know if it was at full potential, or not, but i was pulling a little on him, or at least so it seemed to me . Hope for better on the next runs.
                http://www.youtube.com/watch?v=uytw-...layer_embedded
                • #83
                  Dyno graph
                  • #84
                    Nice one Cosmin!Good luck this year in drag races.Hope to see you back home in the summer.
                    • #85
                      11.3@211 - 1.99 ft , used als, but bad setting on LC - 4500rpm, or so , and bogged a little, a little wet surface, but I think that with good start 10s run can be made in this configuration.
                      • #86
                        • #87
                          http://www.youtube.com/user/vcosmin?feature=mhee
                          http://www.youtube.com/watch?v=M2UO3_3jC68
                          http://www.youtube.com/watch?v=4nSpu...eature=related
                          http://www.youtube.com/watch?v=9TQok...layer_embedded
                          New race, could not get under 11.05 .
                          I had some good 60ft - 1.68 - 1.7x on street tyre, and not so good road surface, but i did some 11.2, 11.1, and 11.05. I will make some changes on rear suspension / and maybe try the drag radials.
                          • #88
                            Update, just found the weight of the car - 1400kg with driver on board. Seems a little to much, i'll try to bring the weight down.
                            • #89
                              It's not that much...
                              S4 with climate control ripped out, all seats out except driver and 20L fuel was 1648kg with driver.
                              So you got 250kg less weight already...
                              • #90
                                My car is a B4 which has from factory 1330kg , so yes it is quite much, i also have striped down interior.
