My Audi S2 600Hp+ project 56k warning
This topic is closed.
  • repo
    • Dec 2004
    • 893
    Repo just mapped another engine very much the same as mine and at half throttle it had 1bar on idle.
    Not exactly idle, but neutral. Which I bet You ment...
    e: Here's a goal for You, this was less than 2bar and suffered from lack of spark power. You can see the power going up and down because of misfiring...
    • terrybullwon
      • Mar 2006
      • 8782
      Good luck to you Alex!
      Repo I hope I can make that pretty easy!
      Chef
      • Jonnybravo
        • Aug 2008
        • 2051
        1 bar @ idle ?
        • terrybullwon
          • Mar 2006
          • 8782
          Originally posted by Jonnybravo
          1 bar @ idle ?
          Yes neutral gear
          Chef
          • Jonnybravo
            • Aug 2008
            • 2051
            Anti Lag ?
            • repo
              • Dec 2004
              • 893
              No antilag
              • terrybullwon
                • Mar 2006
                • 8782
                Just got back from running the car up. Getting ready for a drive Sunday! Lamba is still high I will sort this out tonight after more work
                Chef
                • terrybullwon
                  • Mar 2006
                  • 8782
                  Ooh yeah..... It sounds ****ing awsome!!!!!!!!!
                  Chef
                  • smiler
                    • Nov 2008
                    • 435
                    /Thomas
                    RS2-94
                    • Rocco
                      • Aug 2007
                      • 6393
                      • Country: Spain
                      #340
                      James¡¡
                      it is reliable and good install two EGT sensors in the turbo hotside??
                      one for example for the Aftermarket that you have and the other one for use it in a gauge...
                      and...it is better fit in in the exhaust manifold?? or the reads will not be ood??
                      • Puglife
                        • Jun 2006
                        • 731
                        Vids or STFU Seriously james I'm excited to see the car all done Blood sweat and tears borther
                        Jay - pug_life85@hotmail.com
                        1986 Audi UR quattro - WORK IN PROGRESS
                        1981 VW Mk1 Golf - "20v Jim, but not as we know it!"
                        • terrybullwon
                          • Mar 2006
                          • 8782
                          Keeping the dream alive.......
                          So far i have sprayed the inside white, with no rubber flooring left (about 15kg)
                          welded in a anti lag micro switch under the clutch peddle. started to make a turbo brace.
                          Welded the bucket seats in.
                          Chef
                          • Bram
                            • Aug 2006
                            • 2582
                            Looking good chef, even high up it's feet. Probably going to see it high up front anyway when you launch it at the drag track
                            • terrybullwon
                              • Mar 2006
                              • 8782
                              Aero catches fitted
                              Also found out that my gear linkage was rubbing on a 90deg -3 hose on the slave cylinder. So i changed it to a Banjo £30 lighter
                              Chef
                              • chipsenter
                                • Jun 2009
                                • 246
                                • Country: Norway
                                #345
                                This is how it will sound with the CT67 Turbo
                                My friends Winter track Audi .
                                Volume UP !
                                FEEL THE DIFFERENCE
                                -Audi S2 " The Sleeper" 704hp 880nm
                                -Audi S2 ""Audi S2 Racetrack
