Repo just mapped another engine very much the same as mine and at half throttle it had 1bar on idle.
Not exactly idle, but neutral. Which I bet You ment...
e: Here's a goal for You, this was less than 2bar and suffered from lack of spark power. You can see the power going up and down because of misfiring...
So far i have sprayed the inside white, with no rubber flooring left (about 15kg)
welded in a anti lag micro switch under the clutch peddle. started to make a turbo brace.
Welded the bucket seats in.
