90q AAN supercharged
  • pnanassy
    • Dec 2004
    • 287
    • Country: Hungary
    #31
    Unique,thats for sure!
    Also lot of work involved,hope you like it!
    Do you have any video or timeslip of your 10.1 run thats in your signature?
    Thanks,Peter
    Peter Nanassy
    Custom Engine Management,and Electronic Fuel Injection solutions supplier , contact me for details.
    http://www.carstyling.hu/car_shower.php?id=19845
    http://www.youtube.com/watch?v=FYOVA_285Rs
    • volenv
      • Oct 2008
      • 32
      • Country: Bulgaria
      #32
      The measuring technike does not print timeslips. Also this is completly onother car. It is the weekend dragracer. Clas restriction is 1800cm3. The car is audi 90 quattro with golf KR engine ( 4 cyl inline , the small s2:mischeif running 2.1 bars of boost on methanol Videos will come later.
      About the supercharged car. The boost is 1 bar 1500rpm to redline. Will have to work about a month on it. Plans are handmade rollcage, and stiffer engine mounts. After that on the dyno. And the silencers. Everything is clear. The car just needs nice airbox, and everything is fine.
      Aaaaand cheers, the winter is coming
      Audi 90 1.8 16v turbo
      10.116 235km/h
      DRAGPOWER
      • volenv
        • Oct 2008
        • 32
        • Country: Bulgaria
        #33
        And the ex manifold is custom. After a few days of thinking before fitting the supercharger i found out that it is not possible to place him on the other side without sacrificing the water radiator. So he had to go in front, with the intercooler. And after hitting the first snow bump all radiators will be broken. So it is not an option.
        10.116 235km/h
        DRAGPOWER
        • volenv
          • Oct 2008
          • 32
          • Country: Bulgaria
          #34
          10.116 235km/h
          DRAGPOWER
          • pnanassy
            • Dec 2004
            • 287
            • Country: Hungary
            #35
            Cool,thanks!
            What "problems" did you experienced running methanol?
            Could you please tell me more details about the dragcar?
            Thanks,Peter
            Peter Nanassy
            • volenv
              • Oct 2008
              • 32
              • Country: Bulgaria
              #36
              After another few days of experiments i have landed at deadend. No way of silencing this device.
              10.116 235km/h
              DRAGPOWER
              • volenv
                • Oct 2008
                • 32
                • Country: Bulgaria
                #37
                Need some free time, to make pick's of dragracer and post them.
                10.116 235km/h
                DRAGPOWER
                • volenv
                  • Oct 2008
                  • 32
                  • Country: Bulgaria
                  #38
                  The car is on stock aan turbo. Boosting 1bar. Feels lagy, compared to the supercharger
                  10.116 235km/h
                  DRAGPOWER
                  • maRS2
                    • Oct 2003
                    • 366
                    • Home: France Current: Thailand
                    #39
                    Do you have a bypass system for idle and low throtle?
                    Normaly roots type compressor need such a device actuate by intake manifold vaccum. intake air bypass the compressor at idle and low throtle when vaccum is at max in the intake manifold.
                    this would cancel noise of compress air at idle and cruising.
                    RS2 chip by mihnea,PKM short IM, forge dump valve, 3" custom stainless exhaust, 18"X8" Porsche 996 rims, conti contact 245/35 Front 225/40 Rear, QR sport top mount, Powerflex bushes, aloy sub frame bushes, neuspeed 19mm RARB,Hard tranny mount, V8 torsen on RS2
                    • volenv
                      • Oct 2008
                      • 32
                      • Country: Bulgaria
                      #40
                      Thanx. The SC is screw type, not roots. The car has mechanical bypass valve, which is even better than vacuum activated. The noise is typikal problem of these SCers, so they are usualy located behind the trottle plate, which makes noise isues fine.
                      Aniway, problem is solved.
                      10.116 235km/h
                      DRAGPOWER
                      • knobstar
                        • Jan 2008
                        • 68
                        can we see a video of it in 'muted' mode, then? Sweet ride regardless
                        • volenv
                          • Oct 2008
                          • 32
                          • Country: Bulgaria
                          #42
                          soooooooon:mischeif:
                          10.116 235km/h
                          DRAGPOWER
                          • volenv
                            • Oct 2008
                            • 32
                            • Country: Bulgaria
                            #43
                            Not an S2 engine, only the small brother 1,8 16V I4, my weekend dragracer went to the dyno yesterday. Boost is 2bars. Fortunetly thats the one and only dynorun, as the alternator flew apart.
                            10.116 235km/h
                            DRAGPOWER
                              got a bigger pic? cant see it very well
                              • volenv
                                • Oct 2008
                                • 32
                                • Country: Bulgaria
                                #45
                                10.116 235km/h
                                DRAGPOWER
