AAN into Ur quattro, 400-450 Bhp Target
  • URquattroGus
    replied
    Nice shiny head, now blasted, ported and skimmed, with valve seats given a multi angle cut too, cap caps polished also; thanks to JP aka JNL Racing He also ported and matched my wagner inlet manifold.
    Can't wait to get to get this back on the car on and see what difference it makes
  • quattrostyle
    replied
    to get the best out of the engine a remap is highly recommended after the headwork I'd say.
  • URquattroGus
    replied
    So, head is off and away for porting and reworking of the valve seats etc
    Wagner manifold will be port matched too.
    I am also going to look at having one of the intercooler end tanks re welded for a lesser angle to improve the inlet tract a little.
    Once the head is fitted back on, should I go for a remap?
    I was thinking about either buying an Innovate LM2 and checking AFR's or going to a local rolling road and getting them to do it. Presumably as long as AFR's look to be in order it should be ok and avoid yet another remap?
  • prj
    replied
    Just stick with stock cams.
    I've tried so many things, and always come back to the stock setup in the end for drivability.
    At least under 500hp.
    Yes, you might win some up top, but in reality, it's always a tradeoff.
  • 20Vcqdriver
    replied
    Originally posted by DJones
    I have seen one somewhere but cant remember where....
    I'm pretty sure that the summary was 7A exhaust cam introduced more lag with higher top end (which you would expect with more overlap) and the standard aan ex cam was obviously the opposite.
    I am amazed that just a few degrees and more lift has so much differnce, According to my data the cam opens at the same point but closes just 6 degrees later with I think it was 1mm more lift. Perhaps an adjustable gear on the exhaust cam could be designed to 'fine tune' for the best compromise
  • DJones
    replied
    Originally posted by 20Vcqdriver
    I was looking at a 7A exhaust cam, read all the threads and still not sure, a dyno graph of before and after and a before and after point of view from those that have done it would be good..
  • 20Vcqdriver
    replied
    Originally posted by URquattroGus
    Now the head is coming off for some headwork, should I change my standard AAN Cams??
    I want the best torque but also top end.
    I have been told that ADU cams are the best for torque, but that this would mean swapping water pump and belts etc? Also, I would have to find some and they are no doubt rather expensive to source....
    I didnt go for a 7A exhaust cam, should I try this? What is the benefit of using one?? Higher lift?
  • URquattroGus
    replied
    I presume this is only for top end gains?
  • URquattroGus
    replied
    Head porting here i come....
    Looked at buying stuff to log pressures etc at large expense but have decided to get head work done first.
    Then I can look at methanol or different coolers if still not satisfied.
    replied
    I did an article for Audi driver on fitting water inj. Can e-mail to anyone interested
    Yeah that be good to see
    replied
    Sent you a pm, I will upload it and create a new thread
  • 20Vcqdriver
    replied
    Originally posted by Jamo
    Would be good, you should be able to attach virtualy anything to the forum, and I think this information and line of talk needs it's own thread not in this gentlemans project thread
    Tried uploading the PDF but as previous attempts in the past, comes back as upload failed, so back to anyone interested, PM me an e-mail address for article.
    replied
  • 20Vcqdriver
    replied
  • prj
    replied
    Originally posted by 5cylinderman
    For chargecooler information have a look at www.frozenboost.com
    Not a good website to get good information, as obviously they are trying to sell a product there.
    They say that drawing heat out of the cooler with air is more efficient than using air...
    This would be correct, assuming the water would be magically cold all the time.
    However, you have to:
    1. Draw the heat out with water.
    2. Then use AIR to cool the water.
    Simple physics - it is lots more efficient to just use air to cool the cooler DIRECTLY.
    That's where the entire thing falls completely flat on it's face.
    If your engine is at the front, unless you are doing drag racing, forget it.
