3b s2 coupe resurrection
  • andy10v
    • 5996
    Injectors ok, operator error
    Steve was kind enough to have a chat with me on the phone, I did not operate the throttle when doing an output test Injectors click after the throttle has been opened.
    So I would now appear to be missing spark, now checking the dizzy hall sensor wiring
    brown/yellow wire has continuity to the intake manifold
    red/black wire has 5V
    green signal wire has continuity back to the ECU
    Sold ABY-stock
    • twoqu
      • Sep 2003
      • 3103
      #1247
      Not sure how John's (or indeed others who have converted to COP) but I have seen it done by taking a power feed off the alternator to a relay and triggering via the original coils feed.
      • andy10v
        • 5996
        Originally posted by twoqu
        So we are now looking at sparks!
        Wonder if you have somehow interchanged the two sensors connectors. Doubt whether that would stop it starting.
        Start with power to the coils.
        Yes, sorry
        Which sensor connectors?
        Sold ABY-stock
        • andy10v
          • 5996
          I have 12v from the old coil feed.
          I have earth at the old coil earth (plus and earth onto the cam cover)
          Sold ABY-stock
          • twoqu
            • Sep 2003
            • 3103
            #1250
            The coolant and IAT!
            Power and earth at coil plugs as well?
            • andy10v
              • 5996
              Cylinder 1 coil plug
              Pin 1 12v
              Pin 2 earth continuity
              Pin 3?
              Pin 4 earth continuity
              Sold ABY-stock
              • andy10v
                • 5996
                I have continuity from coil plug 1 signal wire back to the ecu
                Sold ABY-stock
                • quattro-nick
                  • Sep 2012
                  • 1746
                  • Country: Belgium
                  #1253
                  pin3 is the signal wire for the coil
                  are you sure the dizzy is ok?
                  You can measure the signal at the green wire with a multimeter,just put the meter on volt(dc),the black pin on ground or brown/yellow wire and your red pin on the green wire
                  by cranking the voltage goes up and down
                  TWINCHARGED power,zero lag
                  AEM W/M injection
                  • twoqu
                    • Sep 2003
                    • 3103
                    #1254
                    You have eliminated the flywheel pin so the hall sensor is the next obvious culprit!
                    • andy10v
                      • 5996
                      Just tried that, not a thing from the multimeter.
                      I guess the hall sensor in the dizzy shat itself?
                      Sold ABY-stock
                      • andy10v
                        • 5996
                        (Multimeter set to 20v, black lead on IM, red lead on middle pin of dizzy plug)
                        Sold ABY-stock
                        • quattro-nick
                          • Sep 2012
                          • 1746
                          • Country: Belgium
                          #1257
                          i would try an other dizzy if you have one
                          AEM W/M injection
                          • twoqu
                            • Sep 2003
                            • 3103
                            #1258
                            It might depend on the sophistication of your DMM I fear.
                            Here's another method:
                            http://www.efiexpress.com/catalog/ar...articles_id=11
                            • twoqu
                              • Sep 2003
                              • 3103
                              #1259
                              Check for the 5V reference as well.
                              Looking at the wiring the grounding for the hall sensor looks to be on the same circuit of the other sensors you mentioned previously. So check for the 5V against the hall sensor ground and then a known good ground to double check.
                              • andy10v
                                • 5996
                                Cheap ones dont react fast enough?
                                I saw the LED one, just dont have LEDs lying about the garage.
                                Sold ABY-stock
