80Q Competition 20VT inside¡¡
  • Skull
    • 3506
    • Country: Slovenia
    #31
    yes, sure they are expensive. get them used...
    Audi Quattro WR
    • Rocco
      • Aug 2007
      • 6393
      • Country: Spain
      #32
      do you know a place where to buy them??
      ebay.de??
      • Rocco
        • Aug 2007
        • 6393
        • Country: Spain
        #33
        you need s2 avant/limo rear hub housing. the compi are 75mm. on the front you can mount s2 coupe hubs with housings.
        if they come from RS2 Avant ...could be valid too??
        many thanks¡¡
          Just sold a set, your out of luck, PM jonnybravo, he's destroyed enough avants he should have some
          • sam80quattro
            • Oct 2006
            • 1496
            pnanassy... that is some turbo damper
            • Rocco
              • Aug 2007
              • 6393
              • Country: Spain
              #36
              thanks Jamo
              i will do it
              NOW
              • Skull
                • 3506
                • Country: Slovenia
                #37
                http://cgi.ebay.de/Audi-80-S2-Avant-...item518b3b946a
                http://cgi.ebay.de/HINTERACHSE-RADNA...item5885e08af9
                Audi Quattro WR
                • Rocco
                  • Aug 2007
                  • 6393
                  • Country: Spain
                  #38
                  and about important thing like brake sistem.... of course i will upgrade it with brembo calipers, but talking about sevo pump,brake reservour,brake lines, and brake pump.....
                  it is possible to upgrade it with the S2/RS2 brake sistem easily?
                  Skull helloooo
                  • Skull
                    • 3506
                    • Country: Slovenia
                    #39
                    if you will install a 2.2t engine, you will probably have to change the braking servo to the s2 specs. the lines are the same from the abs to the calipers.
                    Audi Quattro WR
                    • andy10v
                      • 5996
                      Are coupe and avant/saloon propshafts not different lenghts, or one half of the prop is?
                      Sold ABY-stock
                      • hermanio
                        • Jan 2009
                        • 805
                        yes they are different length.
                        5 Cylinder Freak
                        • 20vQC
                          • Aug 2007
                          • 684
                          • Current: Italy
                          #42
                          lol peter nanassy's engine bay pic won!!! looks nasty! Tomas, think about your 4cyl on N/A form... 10K rpm, 270bhp like on the BTCC, 4 throttle bodies, a big exh tubular manifold, 5valve per cyl and a nice weight reduction! you would have the turbo engine on the coupe, and the revvy n/a on the Compi!
                          - Looking for a S2
                          - Lancia Dedra HF turbo i.e. (4sale)
                          - Typ89 Coupè quattro, 20Vt AAN, VEMS, K24-7000@1.3bar (scrapped )
                          • GazzaG60
                            • 4133
                            10k on a 4 pot NA costs $$$$£££££€€€€€€€
                            and will be a pig to drive.
                            16vt bang for buck everytime.
                            • dominator
                              • Jan 2010
                              • 736
                              • Country: Bulgaria
                              #44
                              Why do you want to change the servo with the bomb?It is possible to use the original brake sistem.Several friends use it here in Bulgaria.
                              • Rocco
                                • Aug 2007
                                • 6393
                                • Country: Spain
                                #45
                                maybe because i will use my current 385x36 discs with Audi ceramic calipers?? and surelly i need a perfect working condition with brake sistem...
                                thanks for the advise ,we will see what happend
