80Q Competition 20VT inside¡¡
i have to present the car officially to my parents and girlfriend....so i have to homologate the car,repaint it with another colour and start bushing the car,suspension,etc...
Now you have a good street legal
car...what do you think to do with it??
When you finish the car, suspension, brakes, silentblocks, paint, wheels...what will you do?? Stroker inside the coupe
Good job Prj
I will try to see you the next time, I have all what I need except the turbo
Did you do a remap in the S4??
about the coupe i would say yes, but now i am a bit scared...
Dmitri told me "sell the coupe as stock,and every upgrade parts inside separately and then buy a RS4 B5
,to have 2 different worlds because now i cant get anything better as 2.2 20VT engine as the the competition one so it should be boring for you "
LWB Audi Sport Quattro projectComment
i would say yes.... for sure.
too much power on a street car... if you lose the control on the car you could die in a second... it has to be perfect or with 100Hp less
whem the wastegate opens the screamer exhaust is lovely as a hell
a helmet also will help
I have baptized it as "The Noise"
What do you think your family??i have to present the car officially to my parents and girlfriend....so i have to homologate the car,repaint it with another colour and start bushing the car,suspension,etc...
and what do you think about your family cars??
Dmitri is crazy....you don't need to sell the coupe
on a street wheels
nice nickname
none of my family except my brother and cousin knows anything
i only have the coupe and the competition ....the S4 was sold
Bigger cojones my friendi had a drive now...for 10 minutes.... and STILL scared
too much power,it´s also practically undrivable on WOT mode....1st and 2nd gears are a madness. i am still trembling
and in higher gears....you can feel how it push your back till redline set at 7500rpm
i have never felt anything similar...
what a beast my god
I don't think it's that bad. Yes, it's pretty fast and lacking traction in first, but you can still launch it, shift into 2nd, 3rd... I had no problems mapping it alone most of the time, but it needs some work to hold straight with one arm in 2nd after 5000 rpm when it loses traction.
It's on the streetable limit. Just don't kill yourself with that car in a curve or slippery weather.
Good luck with the restoration.Last edited by prj; 29 December 2011, 06:37.Comment
It sounds like a very nice result. Rocco, if you are too afraid, stick a smaller hotside and reduce the boost on the high revs so as to keep the power less and make it more drivable!!! hahaha!!!
i wouldnt do it though, 4200 is not bad at all and this engine is made to go high revs rather than early spool!Comment
hehe, no thanks because i would need to remap it again... and maybe i would only win 200/300 rpm?¿ better spool and 30Hp less?It sounds like a very nice result. Rocco, if you are too afraid, stick a smaller hotside and reduce the boost on the high revs so as to keep the power less and make it more drivable!!! hahaha!!!
i dont want to spend any money for now....to get more power. i only want the car running almost perfect...bit a bit...RED Mitsubishi Lancer Evolution VI TME nº 16 of 250
This engine does not breathe below 4500 rpm... That would be a waste of time and only make the car worse.It sounds like a very nice result. Rocco, if you are too afraid, stick a smaller hotside and reduce the boost on the high revs so as to keep the power less and make it more drivable!!! hahaha!!!
The strongest torque comes in at about 4800, long after the turbo has spooled up and holding 2.2bar.Comment
One of the logs...
Boost actually does not oscillate like this. There is no restrictor, so you can see the pulsations in the inlet manifold.
Also you can see that while you reach peak boost at 4200 rpm (boost is a bit late on the graph), the peak load or cylinder filling at the same level is reached at 4700-5000 rpm.Comment
Can it be that when the engine reaches 4700+ the turbo also works in a higher efficiency island in the map?Go Holset or Go RS4Comment
