Terrybullwon's Racing S2 coupe
This is a sticky topic.
  • Jon441cc
    • Dec 2005
    • 2061
    Still have to press down clutch pedal ?
    • Jonnybravo
      • Aug 2008
      • 2051
      Is that the ikeya (sp) sequential shifter ?
      Mike Rainbird of r&b Motorsport runs that or one very similar on a ludde dogbox in his escort, seems a nice bit of kit.
      Have you sorted out a gearbox or kit yet James ?
      • Jonnybravo
        • Aug 2008
        • 2051
        If its a dog box then no clutch on up shifts
        Not sure if its the same shifter but its a sequential shifter Mike now uses on a H pattern dogbox, Adrian at Fensport has run the same in his car for a fair while now.
        • speeding-g60
          • Aug 2008
          • 1186
          i am going to guess 700 Euro.
          it is still being developed.
          and not sequential.
          looks like 8 weeks or so out i heard.
          and when used with a dog-geared trans no upshift clutching....
          • terrybullwon
            • Mar 2006
            • 8782
            Yes James I spoke with Elite transmitions
            Should have something from them by the end of the year, also I got this to day it weighs about 2-3kg
            Chef
            • Holger
              • Dec 2005
              • 13
              • Home: Germany Current: United States
              #111
              and not sequential.
              CAE-Racing ?
              Didn't know they work on something for Audi.
                Cool, I hope you will blow over the carbon in pearly white mate?
                • AndyP
                  • 6049
                  Where from?
                  • terrybullwon
                    • Mar 2006
                    • 8782
                    I got it 2nd hand, i think its custom made the aero latches are counter sunk and made to fit the bonnet i have not seen this before on any others?
                    Chef
                    • JP
                      • 1858
                      SQS do a H pattern to sequential shift conversion for the 01E box
                      I believe its the aforementioned ikeya unit.
                      UrS6 Stroker + HTA3586 =
                      • terrybullwon
                        • Mar 2006
                        • 8782
                        Yeah kind of like this as well
                        http://hpower.de/shop/product_info.p...E-Dog-Box.html
                        Chef
                        • terrybullwon
                          • Mar 2006
                          • 8782
                          Well alittle up date.
                          I have modified and powder coated the sub frames and hubs. Front sub frame had more metal removed so the the 102mm down pipe fits with out stopping the adjustment of the sub frame.
                          Rear one has had some serious diff bracing so the whole drive chain should be pretty ****ing tight now!
                          Got a dry run of fitting the rear blades with the tubular wish bones today they look okay still abit of work to do there though.
                          Sorry for the bad quality my camera took a beating.
                          Beef'd up rear diff mount
                          Chef
                          • terrybullwon
                            • Mar 2006
                            • 8782
                            Oh and i still have no suspension!
                            Chef
                            • nervas
                              • 357
                              • Country: Lithuania
                              #119
                              hi, not the best design of mcpherson control arms.. on braking you will have problems with outer spherical bearings, it can unscrew... If you want to test then put there 2x nuts, but it would be better to have there welded housing for round spherical bearing for safety.
                              had similar design years ago.. it works with double wishbone, but not mcpherson
                              Xtra Racing
                              • andy10v
                                • 5996
                                Are zip ties not taking the weight saving to the extreme?
                                Were you worried about the original diff mount on the subframe flexing? Are the wishbones "set" in the subframe or will you use spacers to adjust back and forward?
                                You got a date for the suspension?
                                Sold ABY-stock
