Audi Coupe Drag/ Trackday car
  • Rallye20vt
    • Mar 2008
    • 154
    Building an audi coupe into track day car.
    Sorry for my bad englisch
    So far the movement till now :
    Engine:
    AAN Basis From Urs4
    1 mm skimmed pistons
    New piston rings
    Engine honed
    H Beam conrods
    Glyco Bearings
    Arp headstudkit
    CIlinderhead checked
    7A Cover machined to fit the V8
    New cambelt, waterpomp, spark plugs etc etc.
    Holset HX35 Turbo
    440 cc Injectors
    Chip from PRJ
    Joe 650 + nm clutchkit
    01A S2 Gearbox
    Brakes:
    Front Audi A8 discs 360 mm
    Porsche 997 Big red calipers
    Ebc Brakepads
    Rear:
    Audi S4 V8 ( 06) complete brakekit 305 mm
    EBC brakepads
    Still have to fabricate a couple of holders for the longer
    hand brake kabels.
    Car itself, completely stripped, S2 hubs,
    A8 18 inch wheels with semi slicks tires.
    Kw Variant 2 Shoks.
    At the moment we are building the roll cage,
    The rear is almost done, than we go to the front.
    Its gonna be a bolt in cage not welded in.
    Still searching for a good exhaust manifold, than the engine
    and gearbox can be mounted into the car.
  • Rallye20vt
    • Mar 2008
    • 154
    SKimmed pistons with conrods
    Honed the engine
    New bearings, pistons in
    Arp headstus , new headgasket
    Head on new belt, V8 COils mounted
    New turbo Holset HX35
    Engine almost done
    Checked the Rear Diff, new oil etc.
    Welded the center diff
    440 cc injectors
    Bolted gearbox on today
    Front brakes
    360 mm A8 Brake discs
    Calipers for the front brakes from epytec.de
    Rear Brakes
    KW Shoks
    [img]http://www.mijnalbum.nl/Foto-NHJIPUJ6-D.jpg[img]
    Rollcage untill now
    Rear section is going to be boxt in. Still working on that.
    Today got the Apex boost gauge in
    You can adjust the gauge into max boost with a signal.
    • Rallye20vt
      • Mar 2008
      • 154
      • Rallye20vt
        • Mar 2008
        • 154
        The Car itself.
        • Nuno Cristiano
          • Aug 2010
          • 421
          • Country: Portugal
          Nice project
          I small question why you welded center diff? What is advantage?
          I hope your injectors are short to your Holset
          .: MINI Cooper D 08' :.
          .: Audi Coupe Quattro 20V 91' :.
          .: Audi Porsche RS2 95' :.
          • Rallye20vt
            • Mar 2008
            • 154
            More fun on the track
            Yes the injectors are good enough,
            440 cc is @3 bar, i have a 4 bar fpr.
            PRJ says it works
            • quattrostyle
              • Oct 2006
              • 6229
              Nice car, did this one belong to Bart?
              What intake is the dark on in the picture?
              • Rallye20vt
                • Mar 2008
                • 154
                Yes the car was from bart.
                The black intake doesnt fit, its a rewelded one, but they drove it with a different
                type of sterering pomp.
                • Rallye20vt
                  • Mar 2008
                  • 154
                  DOes anyone have the motor mounts,
                  ( alu brackets witch bolt to the engine )
                  I left the URs4 on but it doesn;t fit into the coupe.
                  • quattrostyle
                    • Oct 2006
                    • 6229
                    I should have some for you
                    • Rallye20vt
                      • Mar 2008
                      • 154
                      Please Pb me your adres + Price
                      I need them asap if that;s possible.
                      • Rallye20vt
                        • Mar 2008
                        • 154
                        Today got to work on the Rear Stabi,
                        Mounted it in, with new brackets, rubbers etc,
                        Welded the 2 ( original S2 and Citroen Saxo ) rods together to a combined 24,5 cm.
                        And tested it with 3 man in the back
                        My car as you can see is not running so i tested it this way
                        • Rocco
                          • Aug 2007
                          • 6393
                          • Country: Spain
                          this colour sounds me familiar
                          wich one is the advantaje or dissvantage of welding the center diff?
                          • Nik0las
                            • 1345
                            • Country: Bulgaria
                            PRJ might say that 440cc is enough but for me they don't - sorry!
                            What power you're after? HX35 size is something like gt30r (even bigger) on 2.0bar boost these inj. will be not enough.
                            Calculate your self:
                            • Rallye20vt
                              • Mar 2008
                              • 154
                              Dont know about that go on his experience.
