Project Progress, inletmanifold, paint etc.
  • Dutch_RsBlueS2
    • Sep 2003
    • 285
    Here some pictures of my project progress, wich started with just a 3B to ABY conversion went a bit different.
    I`ll post all the new pictures an progress over here.
    First my car before the paintshop
  • Dutch_RsBlueS2
    • Sep 2003
    • 285
    then after some paintwork the paint looks like this.
    • Dutch_RsBlueS2
      • Sep 2003
      • 285
      the whole driveline is also sandblasted an coated with some industrial container coating so it will never rot again
      Here`s the front subframe with some new gearboxrubbers, and aluminium selfmade bushes.
      • Dutch_RsBlueS2
        • Sep 2003
        • 285
        the last days i`ve been busy with my inlet manifold wich started like this
        • Dutch_RsBlueS2
          • Sep 2003
          • 285
          and after some minutes it looks like this
          The 5 new runners all equal lengt.
          • Dutch_RsBlueS2
            • Sep 2003
            • 285
            and after some heating an reforming the runners are looking a bit better
            • Dutch_RsBlueS2
              • Sep 2003
              • 285
              some aluminium welding (picture taken by Jeffer)
              • Dutch_RsBlueS2
                • Sep 2003
                • 285
                after welding the runners to the original flange.
                The steel mold you see is made out of a wagner tuning manifold so all the flanges are in a correct position.
                • Dutch_RsBlueS2
                  • Sep 2003
                  • 285
                  then some progress with the box on top of the runners
                  • Dutch_RsBlueS2
                    • Sep 2003
                    • 285
                    inside peek in the new manifold, it is not finished yet but it will be tomorrow i hope. So dont mind all the rough edges, and its not fully welded.
                    • DJ-ROY
                      • Dec 2004
                      • 710
                      NICE WORK DUDE too much {schiet al op} .
                      RS for ‘Rennsport’ - ‘Motorsport’ in German
                      • RIX
                        • Jul 2004
                        • 229
                        • Country: Denmark
                        that´s some nice welding ,wasn´t you and jeffer that made the alu flywheels,you guy´s have some wery good working places ,wish mine where that good .
                        Best Regards
                        RIX
                        • Bibby
                          • Aug 2004
                          • 1043
                          Look forward to seeing how it all goes!
                          acidtrax
                          • Tommy200rs
                            • 285
                            Note that the propper internals/entry in the collection chamber is a must for filling in the air evenly into whole inletmanifold chamber.
                            Then when the filling flow is even to the collection chamber 1 you can deliver it into chamber 2 from where it goes to each runner tube. Otherwise the some cylinders may get more air than others and then lean and some richer.
                            One chamber design is not good. See all the IMSA pictures you can find for more hints. This is not easy. If your power level is ~360-380-400hp then stock inletmanifold is ~ok. If you are going to have a tubular exhaust manif, you can measure the exhaust temperatures in each ex runner and see if one cylinder is running lean. Alu flywheel may be too light for a street driven car. Im having only 50% reduced ABY flywheel (one piece version) from CNC shop next week..
                            • Erikb
                              • Jul 2004
                              • 648
                              It is looking grate!!, good work. I wish that I had that kind of skills to make my own exhuast, IM, EM, Flywheel, bushes, crossmember etc.
                              I hope to see it during a next meeting.
                              Getting everything sorted out for my 5++ hp project
