My 1.8t CQ - 2 engines later....
  • #16
    Looking very good.
    On the intercooler, you shouldn't go thinner than a 3 inch (75 mm) core. It looks like you have room for a 3.5" (88 mm) thick core and maybe 4" (100 mm).
    • #17
      Core thickness increases yield a diminishing return after x inches. Better to spend money on more tubes/rows rather than wider or longer ones.
      1995 1PissedOff90sigpic1991 USDM CQ 7aT
      • #18
        Cool project, the engine looks like a really nice fit in there, sooooo much space at the front!
        How low does the sump sit? does it hang lower than the 20vt?
        • #19
          thanks guys.
          I know thicker is better on the ic core and such a small turbo will generate heat. it may not be correct, but most 1.8t's use a 2.5" stacked on the radiator and the bigger turbo guys are using 3" cores.
          Just staying cost effective with a 210hp setup. I never intended on the engine swap and this is pulling time/$$$ from the v8cq. Once the 1.8t is all sorted and goes to a few shows, it will be for sale for the next guy to big turbo it.
          '91 Pearl 3.6 V8 CQ - building
          '13.5 Jetta GLI - toy
          '15 Subaru Imprezzzza - work daily
          hausofdub.com
          • #20
            on the vac lines and little bit of wiring left....almost
            hausofdub.com
            • #21
              Really like that, well done
              • #22
                Thanks, should be a first start attempt later tonight.
                but first...quick 60sec 3d scan. garage computer cant handle rendering faster that 2 fps
                hausofdub.com
                • #23
                  Thats a nice clean install. I like the 3d scanning
                  Eric
                  95 S2 Avant under rebuild.
                  • #24
                    Thanks
                    I have 12v power at each injector via the green/yellow.
                    Output tests do not work for injectors.
                    N80 and N75 click away during output tests.
                    Coil packs fire.
                    Throttle body adapts.
                    Tried 3 557p/n ecu's
                    Swapped cam position sensor from a running 1.8t
                    AEB harness grounded to a body ground with ABS. Transmission is grounded to battery ground body stud. coil packs grounded to valve cover and to battery ground body stud.
                    suggestions?
                    hausofdub.com
                    • #25
                      hausofdub.com
                      • #26
                        Marvellous
                        • #27
                          replaced the throttle body and the maf is not connected yet. no DV either.
                          hausofdub.com
                          • #28
                            #3 coil pack was dead brand new....swapped out a spare. runs much much smoother now.
                            sits at 202* F at idle 850rpm.
                            drops down to 199* F at 2300 rpm
                            Hits 207* F while holding rpm and bouncing the revs for extended periods then cools back down to 202* F
                            hausofdub.com
                            • #29
                              Sounds like it is working nicely then
                              • #30
                                had a bad throttle body days before Southern Worthersee. New used tb came in on Tuesday and the battery was totally dead. First fire since. It was late so I couldn't be too loud. I try to be a nice neighbor.....
                                hausofdub.com
