My 1.8t CQ - 2 engines later....
  • #46
    Originally posted by gavs20v View Post
    Out of interest couldn't you have used oem mounts from the n/a 1.8 20v b4 cabriolets ?
    Or are they different ?
    Great project
    Gav
    the oem b4 cabrio mounts work in the b4s equipped with the V6 engine, in a 5 cylinder car the mounts are in different places.
    those mounts are what i used for my conversion in a b4 v6 limo:
    You can see there are mounting points for the bolt on style engine mounts, a lot different from the 5 cylinder stuff:
    6 cylinder mounts:
    • #47
      Originally posted by Ruffiano View Post
      It is nice having an obd2 port and an ecu that you can log data with.
      Is that radiator keeping the temps down enough? What did you do for a coolant sensor? Mine runs to the stock dash but reads like an A4 when warmed up (gauge needle is vertical).
      Its 86*F outside right now. At idle the car holds steady at 202*F. Cruising its around 195*F.
      Thanks Gav
      Tonight it will get new trans fluid
      '91 Pearl 3.6 V8 CQ - building
      '13.5 Jetta GLI - toy
      '15 Subaru Imprezzzza - work daily
      hausofdub.com
      • #48
        is it reading to your dash gauge? are you using a stock CQ cluster? or something else?
        • #49
          i do not have the cluster or center gauges hooked up yet. I have been monitoring via vagcom.
          hausofdub.com
          • #50
            hausofdub.com
            • #51
              NICE!!! looks very clean
              BEAST '90 CQ 24v VRT / O1E / v8 rear, HOLSET SUPER 40 http://www.theprojectpad.com/viewtop...1&t=193#p37887
              DD '86 4kq BLAZE, swapping aba/16vT and O1E http://www.theprojectpad.com/viewtop...1&t=201#p38264
              • #52
                I had a great time for the 7th year in a row at H2oI.
                I was super surprised to take a 2nd place in Audi Wild this year. Audi built the car... I built the engine bay.
                hausofdub.com
