Are the motor mounts are not plug and play?
My 1.8t CQ - 2 engines later....
Originally posted by audicoupe2.3 View PostAre the motor mounts are not plug and play?
I ran into a title issue as well. The previous owner had so many 20v's he gave me the title to a b3 20v sedan. I just realized about 2 weeks ago the vin didn't seem right on the title when I was going to get temporary plates. The correct title is in the mail now.'91 Pearl 3.6 V8 CQ - building
'13.5 Jetta GLI - toy
'15 Subaru Imprezzzza - work daily
hausofdub.com
UPdates!
I keep killing 15yr old throttle bodies...so I am adapting to a newer bigger vr6 one.
carbon fiber pla
Put a few miles on the 'ol lady the last 2 days!
hausofdub.com
hausofdub.com
Thanks guys!
I am not sure what was up with all the throttle bodies...but now looking back... I may have been having issues with my old "VWTool" software and cheap obd2 cable doing the adaptation. I threw away all the stock throttles and cannot test them on the new cable. I have since bought real vagcom/vcds have had no issues.
I am currently running a '98 MkIII ABA throttle body as my buddy has the vr6 one and my PLA prototypes to make me a billet one. I discovered the CF PLA adapter worked great...but after the engine is shut off for a few hours and heat soaks the intake manifold...the CF PLA warps causing a massive leak. If I used ABS on my prototype it may have been just fine. I also think if i had an intake spacer the heat soak would be as bad either...but the CF PLA while running prevented heat soak into the throttle. Throttle was always cool to touch. I might still make an ABS one to try out.
The CF PLA feels stronger, feel more solid. I am using it from now on on all my test parts.
Those LED bulbs are kinda weak. Also the autocheck says the high beams are burned out....needs more resistance I assume. I have a new H4 set coming and have a new 30w 2000 lumen per bulb H7 set to try in my GLI. I installed this same set but as an h4 in my buddies car and he loves them, pretty bright.
H7 set
hausofdub.com
hausofdub.com
Made a catch can from some donated scraps.
hausofdub.com
Added an OBD2 port finally
hausofdub.com
It is nice having an obd2 port and an ecu that you can log data with.
Is that radiator keeping the temps down enough? What did you do for a coolant sensor? Mine runs to the stock dash but reads like an A4 when warmed up (gauge needle is vertical).
