South Africa 2008 My 1996 ABY S2
  • orsum
    • May 2010
    • 1213
    • Home: United Kingdom Current: South Africa
    #46
    So so true.
    Still I am optimistic and I am 100% sure no matter what happens the car will get what it needs.
    It a bit like waiting for Christmas.
    Worked on the Porsche brakes today
    orsum
    • orsum
      • May 2010
      • 1213
      #47
      One year later and some but not all the work has been done
      All engine and gearbox mountings replace with OEM parts. Gearbox mountings fell to bits the rubber split in two. The old engine mountings were 10mm lower than the new OEM replacements. good job I decided to do all the mounting
      Timing belt, crank gear cog, water pump, thermostat, one water hose, hydraulic return line and flywheel sensor bracket replace.
      Busy fitting new exhaust manifold, all new copper nuts, Mint condition RS2 turbo, Bosch 440cc injectors, R8 ignition coils and upgraded Motronic ECU. Fitting the exhaust manifold is a pig of a job
      • Mr G
        • Jun 2008
        • 196
        • Country: South Africa
        #48
        Well done........I definitely admire your patience and persistance. I'm sure it's going to be well worth the effort, sweat, adult language, skinless hands......
        I'm sure you cannt wait to really drive her!!!!
        • Es-Tu
          • Nov 2017
          • 7
          Awesome! nice work
          • orsum
            • May 2010
            • 1213
            #50
            Pictures to follow.
            New cast manifold fitter, RS2 turbo fitted and new coil pack wiring fitted.
            Car started first time.
            Now for the ECU, injectors and DP.
            • orsum
              • May 2010
              • 1213
              #51
              Pleased with how it has turned out so far.
              Looking forward to the first drive.
              • orsum
                • May 2010
                • 1213
                #52
                Boost leak fixed now for the Porsche front brake upgrade.
                Callipers refurbished, 323 diameter disc, pads, Textar Cera-Tec anti squeal lubricant, flex brake lines, new bolts and caliper brackets finished. Should be fitting the weekend.
                  • orsum
                    • May 2010
                    • 1213
                    #54
                    Fitted the new calipers and discs the weekend.
                    Still need to bleed them.
                    Getting close now.
                    • kinaputt
                      • Jan 2012
                      • 285
                      • Country: Norway
                      #55
                      Looks great!
