Quick run round south Bristol confirms that the engine is operating as expected
A few things I've noted: the metal release bearing makes a bit of noise; solid mounts are fine anything above idle and less than full chat & cutout valves aren't subtle...
Another this is that my oil temperature is a little more keen to rise than before, only 1 notch and all other factors are as before. I did have a different oil thermostat housing fitted, as it came with the engine, so potential totally it's that...
Need to do some front suspension work still and fit a cold air feed as it's flat in traffic.
