Project 91 Coupe to AAN'd 400+HP SSSSSSSSSSomething
  • elijahallens2
    • Aug 2004
    • 310
    Hey guys, I thought I better start a thread in the project session since this is definatly turning into a deep project. Ok, so far what I have is a 91 coupe that has all the wiring harness run and the engine mounted. Waiting for custome aluminum radiator as well as a custom motor bracket to fit around the tube header I'm trying to fit. The engine is built with RS2 injectors, RS2 MAF (for now), K27 7200 #6 turbo (replaced by K27/29#8 if tube header improves flow enough), port and polished head, 7A cams, RS2 intercooler (looking for replacement, any help much appreciated), Dahlback intake manifold, 11lb aluminum flywheel, centerforce clutch, DSY 6 speed tranny (waiting for mounting hardware), mocal 19 row oil cooler, stock oil cooler used for tranny fluid cooler, dahlback BV, pauder rods, arp head studs, multilayer head gasket, 3" turbo back SS exhaust with WG exhausted separate (still in the works). As for other stuff, RS2 fiberglass front bumper, RS2 headlights, B4 hood (would like carbon but don't want hood pins and want strength to at least 260kph), Porsche big black brakes with 323mm Porsche rotors and custom aluminum hats, 95 S6 rear vented discs and calipers with custom brackets, H&R springs with Koni adjustible shocks, aluminum subframe bushings, whiteline rear ARB, open for suggestion on front ARB, and I think thats most of it. I will keep this thread alive for a while while it all comes together. Here are a couple pictures to get it going.
    Elijah
    91 Audi Coupe Quattro- AAN engine transplant
  • elijahallens2
    • Aug 2004
    • 310
    another
    • elijahallens2
      • Aug 2004
      • 310
      wheel and front brakes
      • elijahallens2
        • Aug 2004
        • 310
        engine bay in the works
        • elijahallens2
          • Aug 2004
          • 310
          header in place but...
          • elijahallens2
            • Aug 2004
            • 310
            And then the manifold hitting the motor bracket problem
            • elijahallens2
              • Aug 2004
              • 310
              I'll keep taking pictures as I get this car on the road.
              Elijah
              • 90quattrocoupe
                • Nov 2003
                • 771
                Elijah
                Elijah,
                Do you have these brakes mounted or is this for the future?
                I am wondering because, the S6 rear rotor is too deep to fit on the rear of a coupe. I have an S6 I am parting out and tried to use the S6 rotor on my coupe. The depth of the rotor fouled either the strut mount or the tie rod arm, don't remember which. Hat is too deep to use. No matter what custom bracket you try to install, you will never get the rotor to work.
                You can use the S6 caliper with a 280X22 rotor off a S3/NB, with the S8 caliper carrier. No custom bracket required.
                Write is here about half way down on the first page:
                • elijahallens2
                  • Aug 2004
                  • 310
                  Thanks for the info, where can I find the S3 rotors?
                  Elijah
                  • 90quattrocoupe
                    • Nov 2003
                    • 771
                    Elijah
                    For us in the states the same rotor is used on the New Beetle. I got mine from PureMotorsports, Brembo slotted 280X22.
                    VW and Audi repair, service, performance parts, tuning & diagnostic mechanics. We are located in Miramar, San Diego & specialize in performance tuning, parts, service for these German vehicles.
                    • panzerwagen
                      • 900
                      My man, 90quattro to the rescue!!!
                      Good God Elijah, have you tallied how much you have sunk into your car so far? Got to be big moola! You are either single and live with your parents or you own stock in Microsoft?! I envy you pal.
                      I wish I had the drive you have. When you get to my age, health concerns, a house you are renovating, 2 Ur-Audis, 2 elderly cats. 1 diabetic dog, a mother recovering from cancer and a father in law with heart problems takes a lot out of you. Good Luck Elijah!! Enjoy it all!!
                      • puppetman
                        • 70
                        so ELlijah, are you in Michigan? looks like michigan plate on the red truck. where are you at?
                        • Mark Halligan
                          • 2001
                          Sweet looking coupe Elijah nice spec too.
                          Mark - Modded
                          • elijahallens2
                            • Aug 2004
                            • 310
                            Thanks for the info. You
                            Elijah
                            • elijahallens2
                              • Aug 2004
                              • 310
                              You got it all wrong, I'm a self emplyed builder that has a serious need for speed. My past S4 took me 5 years to get it how I wanted and then one stupid mistake and it was totaled, luckily most of the fun stuff I put on the car was still good so thats where alot of this stuff is coming from. Thanks for the encouragement though.
                              Elijah
