Now I hope you see
Small Urs6 project!
Found some a little older pictures. Bosch 044 installation.
Home made and designed oil catch can.
Here it is not finished jet but you can see.
The air goes in, on the picture left.
Here you can see inside, on air out coming hole.
Here you can see inside, the bottom hole.
All new original lower door trims. Hope they will last some years.
New front brakes are coming one day
Brembo 18 z
I think I don't paint those, I will try to lacque. We'll see how they come out.
They are not finished jet.
Received rotors today. 360mm, big and heavy. They are not connected jet, just wanted to see how they look. I have seen lot of pictures, I knew that they are big but they are super big. Already want to feel how they brake
I was bored last week and I wanted to cover the wire connections. Original plastic one is almost impossible to find. I also wanted to paint the read strud bar black. So, some thinking and here it is.
It was very easy job and cheap too, max 10 euros.
Sorry because of bad picture quality, it is taken with mobile phone
Received Albert's bushings today. I will not change them until I have all bushings that goes under the car. Luckily I have some time, because OEM bushings still work, maybe they are a bit softer than they should be.
More yellow stuff. Bilstein b6 I hope these are good for Estonian's bumpy roads!!
Don't know when I have time to install. I know I must drill some kind of holes somewhere, here in this forum is instruction for drilling, I just need to search.
