Originally posted by quattrostyle
View Post
Small Urs6 project!
Front shocks must wait because building new exhaust will start next week and I must make space, because I want to put bigger muffler to top end to keep car noises down.
Lot of glass glue to avoid water leaks.
Bought new spare wheel, it is 18'' but sadly ET is little wrong, does not fit perfectly and hits brake support. Need to make 1 cm thick flange
Originally posted by maiks View PostNew exhaust muffler should come at the end of the week. Then I can see, maybe it does fit to original position. But if not, then I need to put it across. Will see
REFERENCE: http://www.s2forum.com/forum/showthr...hlight=exhaustRS2'd 93 UrS4 5 spd sedan
Exhaust job comes closer (next week). But some kind of work needs to be done before that. I have seen a long time ago that some rust is under the car so I slowly started to remove that.
Covering with.
First layer.
No no no pretty rusty. Must put new and shiny ones. I will replace brake lines also.
Some parts received today. Sadly, all things are not available anymore. I am sure that somewhere is, but I have no time to wait
