So guys,
As from the subject I will be rebuilding my engine very soon and have no idea where to get the right parts at the right price. Planning to get as much torque as i can from my 2.2 [not interested to stroke it or a diesel conversion] with forged h-beam rods and everything new. Budget is not high but not too low. Torque target would be 600-700Nm with power on 400-500 or crank hp... everything with the help of water/alcohol injection and ron98 gasoline.
Will buy the rods from FCP-enginering, I found that Norbitron sells the tfsi loom for that kind of coils but i need more parts.... all the parts.
Oil pump
Rod bearings
Main shaft bearings
Piston rings
Head gasket and head seals kit
Tfsi black coils
Valve guides
ARP head to block bolts
Any specific fuel pump?
And a sheet with all the tightening torque of every single bolt in the engine.
Will reuse the pistons and my already ported and polished loggie exhaust mani. Stock IC with fresh air pick up and a flat motorcycle fan behind it.
Now my questions. Does a k26/27 [maybe billeted] provide such a high torque? I want it as it is a kkk and keep the stock look inside the engine bay. Will the stock DP hold that power? I have a 3" exh cutoff valve just in the middle of the Y before the cats btw...it helps a lot.
I just want to get as much torque from the engine, no estimated bhp goals, just torque....well okay maybe over 400. Want to keep fully stock engine bay look.
Estimated budget is between 2000 to 2500euro....hopefully with the turbocharger included if i find a tired one to rebuild and billet it.
I have my billeted, rebuilded, ported and polished k2470 that spools amazingly fast...willl be on sale as soon as the car gets to the clinic for it's surgery.
Hope to hear good suggestions about this!
Fabs.
PD. Want to keep my Motronic only in the case i don't find any PnP Vems on my way at a bargain price.
Oil pump
Rod bearings
Main shaft bearings
Piston rings
Tfsi black coils
Valve guides
Fabs.
