85 CQ KV 10V non turbo to 20VT from 95 S6 AAN
  • Macchris
    • Feb 2015
    • 429
    • Country: France
    #46
    thanks for fast response
    i mean the upper metal bar, i think you made one to keep the cutted part in place ? (sorry no easy for me to explain in correct English)
    • seanfillingham
      • Jun 2016
      • 37
      Originally posted by quattro-nick
      you have 2 sort of power after contact (+15)
      problaby you have chosen a +15 that fails when you are crancking
      you need to look for a +15 that comes all the time on contact and crancking
      Yes sorted today all good
      Sent from my SM-G925F using Tapatalk
      • quattro-nick
        • Sep 2012
        • 1746
        • Country: Belgium
        #48
        i have no close picture from the upper piece
        i weld some metal plates underneath the middle piece left and right where you can bolt in
        the vertical bracket is custom made
        if you look good below in the follow picture you can see the 2 bolts left and right where i have cut with a grinder
        TWINCHARGED power,zero lag
        AEM W/M injection
        • quattro-nick
          • Sep 2012
          • 1746
          • Country: Belgium
          #49
          good work!
          AEM W/M injection
          • Macchris
            • Feb 2015
            • 429
            • Country: France
            #50
            ok thanks Nick you should to come yo our annual BBQ Audi meeting east of France near the swiss border i'll be happy to see your car ;-) end of august and there are several Belgians lol
            Tof
            • seanfillingham
              • Jun 2016
              • 37
              Hi.
              Does anyone know the size of the male power steering fitting into the power sterring rack?
              The high pressure side line from the ps pump.
              I have to replace it but not sure what thread it is.
              1985 Coupe quattro typ 85
              • seanfillingham
                • Jun 2016
                • 37
                Size of rad that will fit. Not very big !
                • seanfillingham
                  • Jun 2016
                  • 37
                  Other option to angle the rad. Still tight !
                  • seanfillingham
                    • Jun 2016
                    • 37
                    So I have to address the radiator issue on my build.
                    Do I get a custom alloy rad built for X £££.
                    Also would need a new fan.
                    Or do I angle a stock rad like the second pic?
                    The custom rad would be smaller than the original due to the limited space but can be thicker. Also would hopefully be more efficient than the original.
                    I could go for an uprated alloy rad angled, they are about £460 for the 60mm core. I think I would need that anyway due to the angle and airflow.
                    Any thoughts?
                    • seanfillingham
                      • Jun 2016
                      • 37
                      Well done in !
                      • quattro-nick
                        • Sep 2012
                        • 1746
                        • Country: Belgium
                        #56
                        you can always buy my rebuild AAN intake so the origional radiator can be used on the origional place
                        no problem with 500hp
                        AEM W/M injection
                        • seanfillingham
                          • Jun 2016
                          • 37
                          Very nice. Does that fit without changing anything else?
                          And how much 😆
                          • seanfillingham
                            • Jun 2016
                            • 37
                            Workaround for the throttle cable on the CQ being too long. 15mm plastic plumbing pipe 😉
                            • seanfillingham
                              • Jun 2016
                              • 37
                              For the Water temperature gauge to work had to splice these wires together.
                              So far the only ones I have had to do in the engine bay. The 2 looms work well together.
                              • quattro-nick
                                • Sep 2012
                                • 1746
                                • Country: Belgium
                                #60
                                you have pm
                                AEM W/M injection
