S2 avant
  • Mikes2
    • 1704
    The fuel lines have been chopped just above the brake fluid reservoir
    The other ends are still attached to the rail and the regulator and are just sitting loose in the engine bay
    The blue tape line goes to the regulator. The one with the brass end fitting goes to the rail
    Mike
    http://www.s2-audi.co.uk
    • Mikes2
      • 1704
      Took the starter motor out today to confirm the status of the flywheel wedge pin
      That's all that is left of it
      Mike
      • andy10v
        • 5996
        At least you found an issue.
        What are you going to do to resolve it?
        Sold ABY-stock
        • Mikes2
          • 1704
          I've got no facilities for removing the gearbox so I'll take the engine out instead.
          Clutch pedal is on the floor so debating whether to get a new slave cylinder. I'm a bit suspicious of the Sachs ones at £36.
          It's possible that bleeding it may fix it but it's one of those items that's much easier to replace if there's no engine
          Mike
          • Jas11n
            • 5067
            Ohh, Mike back in an S2
            2001 Avus Silver B5 RS4.
            1995 S2 Coupe - sold (sniff)
            • LHD_Kid
              • May 2006
              • 3697
              #21
              And Jase back on the forum...
              Looks like it's going to be lovely when it's done Mike
              • Mikes2
                • 1704
                Here's hoping.
                Had to use the grinder to the exhaust / cat joints - just full of rust and the bolts had more or less disappeared. Got the airbox and wastegate off but hit a snag with one of the downpipe nuts.
                Will likely be after Christmas before the engine is out
                Mike
                  #23
                  Engine and gearbox out would be the best bet imho given the various jobs you need to do. It will also allow you to do a few other jobs that you haven't mentioned / remembered just yet.
                  A case in point being the two water hoses under the inlet manifold, much easier to do when the engine is out. Others will be able to suggest the other items that'll need to be tackled when the engine is out and 'while you're in there'.
                  Also it will give you much easier access to all the varoius hard to reach nuts that are most likely semi seized and probably not copper greased given the car's age. Taking the engine and gearbox out as one will also allow you to do the petrol pipes with less back strain, as well as to easily clean the painted sections of the engine bay.
                  Alos it's handy for you that you're under no pressure to have the car 'back in service' before Christmas or a deadline in January 2017.
                  As a previous S2 owner, you'll know all of the above, but it can be helpful to hear what others think.
                  Best wishes.
                  • slacky
                    • Aug 2005
                    • 577
                    Great project Mike , good luck with it , look forward to seeing its progress
                    Cab 2.3E
                    90q
                    URS6
                    • Mikes2
                      • 1704
                      Thanks for all the positive comments.
                      Taking the gearbox out is not an option. I only have a garage with a pit.
                      I've managed to borrow a bent spanner so should get the downpipe off tonight.
                      Mike
                      • slacky
                        • Aug 2005
                        • 577
                        You can't beat bent spanners
                        Cab 2.3E
                        90q
                        URS6
                          • 4754
                          You sure? I prefer to stay away from them!
                          • alexqts
                            • Sep 2012
                            • 92
                            That's exactly what I did. Engine out it was
                            Also went through x3 new slave cylinders. The replacements are mainly junk, found a good unit of ebay in the end, it was branded aftermarket but looked like ex-audi stock.
                            Every time I press the clutch pedal I pray it holds up!
                            • slacky
                              • Aug 2005
                              • 577
                              O'dear
                              Cab 2.3E
                              90q
                              URS6
                                • 4754
                                O'dear
