S2 Avant -93
  • Antsa
    • Nov 2016
    • 611
    Email on its way
      • Dec 2017
      • 5983
      • Antsa
        • Nov 2016
        • 611
        Stainless brake piping was made. The one that goes around the rear subframe has so many bends in it that first I had to make a mockup from copper pipe and then I made the final pipe from stainless. Rear subframe also in its place.
        Then it was time to flip the car
        I sanded all the body panels plus the engine compartment. Top of the windscreen had some rust, these were sandblasted and then all the bare metal surfaces got etch primer. Sharktail got removed from the roof. Any tips on what type of aerial fits these cars?
        Before spraying sanding primer I decided to put in all the sound deadeding. I ran out of the butyl sheets so I have to continue next week.
        • K Simmonds
          • Dec 2007
          • 7627
          Hell, you've certain got your work cut out with this project, I normally just use standard copper/nickle alloy brake pipe as I find SS hard to flare nicely with either my hand held or vice mounted tools, half the time it cracks. Do you know what grade SS it is? There's more grades than I can name for all sorts of applications, perhaps it's a softer alloy designed to be more malleable.
          1990 B3 2.0 80 quattro.
          1992 C4 2.8 Avant quattro
          1994 MTM RS2.
          1998 B5 TDI quattro Sport.
          2000 B5 TQS.
            • Dec 2017
            • 5983
            The Avant came with a bee sting style amplified roof ariel as found on many VAG cars of the eara. Nice work as usual
            • Antsa
              • Nov 2016
              • 611
              Hi Kit! The brake tubing is an aeroflow product and it seems to be regular 304, just sold in annealed state. It is harder to form the flares compared to copper, but my tooling seems to do it ok.
              • Antsa
                • Nov 2016
                • 611
                Thanks Dave, I'll begin searching
                • Antsa
                  • Nov 2016
                  • 611
                  I also got a phone call from the landlord a couple weeks back and it seems that he wants to sell the garage. If the next owner doesn't want to sign a new lease, I have to find a new place to continue the project. I'm not too happy if have to move an ongoing project
                  • K Simmonds
                    • Dec 2007
                    • 7627
                    Thanks mate, that make sense as my old Sykes Pickavant vice mounted tool is a decent bit of kit. Guess I've probably been try to flair non annealed steel lines, which is pretty thick, durrr...
                    Will have another go with with annealing any steel lines before trying to flare them in future, I really should have thought of that myself, still you learn something everyday.
                    1994 MTM RS2.
                    2000 B5 TQS.
                    • Rikki Kitto
                      • Feb 2010
                      • 6276
                      Whare are you based I've got a bee sting aerial you can have for postage costs if that helps
                      • Antsa
                        • Nov 2016
                        • 611
                        Thanks for the offer, I'm in Finland. The postage and customs duties will probably kill it.
                        • Rikki Kitto
                          • Feb 2010
                          • 6276
                          No worries sure you'll find one closer bud
                            • Dec 2017
                            • 5983
                            B5 passat estate looks identical. Do you have a breakers yard near you?
                            • Antsa
                              • Nov 2016
                              • 611
                              Yes I actually do. I will have to check what they have. Thanks
                              • Antsa
                                • Nov 2016
                                • 611
                                First stage of sound deadening complete. Tomorrow I will start installing the soft acoustic liner. I ran out of the dynamat and local car hifi store only had ctk in stock, so it's a bit of a mix of brands but they will be hidden under the carpet
