Audi s2 with a few updates
  • rxl
    • 1913
    The rear is almost complete. Filled the diff with oil and just need shims for the Driveshafts as I lost the old ones. Mini brakes are in.
    Gesendet von meinem EVA-L09 mit Tapatalk
    • Arnout
      • Jun 2009
      • 41
      I'm enjoying your updates tremendously from my lazy couch . God job zo far! Thanks also for posting some of the sources of your parts. With Audi parts getting rare and very expensive, that's very helpful.
      • rxl
        • 1913
        3 out of 4 wheels ware not straight so got them fixed and refreshed. Also got a skid plate
        • rxl
          • 1913
          Got the head refurbished and updated all the internals.
          • rxl
            • 1913
            Front subframe is in and the y pipe is also ready for the setup redused to 2x60 for the cats..
              Been following this thread for a while now, great to see it all coming together now. just re read the thread too
              • rxl
                • 1913
                im also glad that i find the time to work on s2.. not so often as i would wish.. have a bunch of parts gathering dust but i think in spring it will be drivable and till winter will enjoy it and after that will be the next step.
                  I can relate to that too, I’m really close to finishing renovations on my house and can dedicate some time to getting parts I have fitted. Trying to get over the flu atm tho
                  • rxl
                    • 1913
                    Few hours spent for the front axle. Need to order front Driveshafts and do the brake lines for the front and the suspension will be finished.
                    • rxl
                      • 1913
                      Testified all the shiny gearbox parts and measured the length of the bolts that I need to order. Also fitted the shifter box. Really tight and had to trim a mm of the sides becouse it would fit so.
                        Which shifter mechanism have you used ?
                        • rxl
                          • 1913
                          It's a custom made from rs4 b7
                            Nice solution, was it a straight forward swap?
                            • rxl
                              • 1913
                              well the shifter box has different mounting point. 2 lower ones fitted the original holes but had to drill a bit bigger and the upper ones had to mesure and drill out. took me half an hour becouse mesured like 10 times.. didnt want to make a mistake there.
                              • 7Aquattro
                                • 12
                                • Home: Austria Current: Germany
                                #90
                                Hi rxl,
                                nice car!
                                Is that a 0A3-transmission from a B7 RS4? What drive shafts do ýou want to use?
                                Cheers,
                                Gilbert
