Ecumaster emu classic vs ecumaster black
  • Tom_
    • Oct 2007
    • 1301
    • Country: Czech Republic
    OEM 5 cyl pedal is from the TOP...OEM TDI pedals are from the ground (mounting) So maybe the best and easiest option will be to adapt stock pedal box, isnt it?
    Audi Coupe Quattro 2.3 20V
    • Thuppu
      • 4115
      Originally posted by prj
      It depends strongly on the stock ECU and how it acts.
      If it has e-throttle and torque management, then probably no (ME7 and up).
      If it is an older ECU with cable throttle, then probably yes.
      Why not adjust the stock ECU map?
      Old ecu with cable, Hitachi MMS-200/300. Don't know if this can be tuned, and if so how it would act with positive pressure..?
        No, TDI pedal box is the same arrangement.
        • Tom_
          • Oct 2007
          • 1301
          Thanks Alex, i look on your topic...stuning work as alwaysDoes have that TDI pedal box some OEM number?
          • orsum
            • May 2010
            • 1213
            • Home: United Kingdom Current: South Africa
            #20
            Hi
            Which ECU did you end up going for?
            • Tom_
              • Oct 2007
              • 1301
              #21
              Ecumaster black, but not installed yet as engine is not finished :/
              • SSPRL
                • Aug 2020
                • 18
                • Country: Ukraine
                #22
                Черный, без настройки выше 0,4 бара
