1. It is possible to tune the stock ECU remotely using my datalogging, I just don't do it. I don't need support nightmares. Also the result is not optimal, correct tuning needs to be done on the dyno.
2. What 1/4 mile time something runs shows nothing about tuning ability. Drag car tuning is the easiest thing you can do since everything but WOT and launch is irrelevant. Also from a proper drag racing perspective 8.6 is very slow. But then you don't do proper drag racing on old audis.
These days if I need to tune 2.2T, I do it on standalone. Simply easier to get support later for the customer.
Not unless I'm out of work locally and remotely, and that doesn't happen often... at all?
Originally posted by RSJ
View Post
Originally posted by S4Marc
View Post
