Actually just found it, and the biggest HFM5 only scales to 1000kg/hr in its standard housing. If you note that 900kg/hr is approx 300bhp then we're left a bit short...
Could be a nice project for someone with a BIG flowbench to try that sensor in larger housing and characterise them.
In rough numbers we need 300kg/hr for each 100bhp, so a 500bhp capable MAF needs to get into 1500kg/hr capability... which is about 50% more than the biggest off the shelf HFM5 package.
Paul
Paul
