VEMS I5 Maps
This is a sticky topic.
Output pin. I had e36 pin 15 but was needed injector output 5. Now fuel pump relay working and engine works sweet
Please send your config if these are not enough so we can check also your configLeave a comment:
Please check if your fuel pump output is inj channel 5, also check it should not be inverted.
Also validate config to see if there is any invalid config entries.Leave a comment:
I also use PNP,
Screenshots are my config, so it should be same with yours. The software shows econoseal, dont care about it.
I am attaching a config for 1.1.94
So there could be different things.
If you need I also can attach a 1.2.2 config if you needLeave a comment:
No pump is not working . I have plug&play v3 but on vemstune it shows econseal typ so I dont know wich pin is for fuel relay.
It would be great if you could send adu config.Leave a comment:
See attached screenshot for audi config upload
also please check if your output channels are selected right/wrong?
Can you hear the pump working when you turn the ignition on?
If you are hearing the pump, then also check your trigger settings. Sometimes small mistakes happen.Leave a comment:
If you are using newest vemstune, it shoud be in
Tools -> Firmware -> config upload
please validate config after uploading(Tick icon in toolbar)
If you want I can send an ADU config for 1.2.2
sometimes some values need changing by handLeave a comment:
Couldn't find default aan
I had 1.1.27 and on it fuel relay was working.
No on 1.1.95 noLeave a comment:
Does someone have stock configuration for AAN or ABY.
I put fuel pump on VEMS output pin 15 for v3 but still not starting.Leave a comment:
My car is on service right now. I am trying to get used to vems. I bough a VEMS in 2009 and never installed. Right now I want to install it. I am just playing with software. And of course a basemap for stock RS2 helps.
Any maps foor newer firmware?Leave a comment:
