While I'm not going to use bleed off valves or standalone engine management, I still would like to install an Air Fuel Ratio gauge to monitor this aspect of my ABY engine.
It can be white or black faced, with a black bezel - No chrome. Similar sized to the oem three small gauges in the centre console.
Can be be digital, if it's better.
Also wanted one for intake air temperature ?
Also where should the senders be mounted for these two gauges ?
Thanks.
Thanks.
and so while the car is being run in / driven with the orignal K24, I can't get it custom mapped as no point, so wanted to keep an eye on the air / fuel and the intake temp on the current set up.
to make it an even three.
