Modifying Motronic 2.3.2 ECU hardware and software.
This topic is closed.
  • -ice-
    • Oct 2011
    • 173
    Hi,
    I was looking for the part, where the actual pulsewidth for the injectors is generated. I suggest it uses the counter module to generate the pulse. Could find some interessting code in IEX5 where it writes CC02 high / low byte. But that would only be one output, how does it select the different injectors then? I basicly think it's sequential, so i won't find five pwms for the injectors running parallel.
    Regards
    • prj
      • Mar 2010
      • 6308
      Originally posted by -ice-
      Hi,
      Regards
      There is a separate 8051 MCU on the top board that does all the sequential injection stuff.
      The main fuel-ign MCU only outputs the pulse to it, and the dedicated 8051 does the rest.
      • -ice-
        • Oct 2011
        • 173
        Ok, thanks for the information. I guess it's the other "30240" 8051 looking IC. I have never seen any datasheets for it.
        Bye
        • -ice-
          • Oct 2011
          • 173
          The cc02 P1.2 output goes to the voltage regulator looking IC on the boost board not to the other fuel processor. So my assumption might be wrong.
          Bye
          • -ice-
            • Oct 2011
            • 173
            Not a good day today All I wrote was wrong
            but i think i have some new findings..
            The ICs that look like voltage regulators are in fact drivers. The five injector outputs are connected to one of them.
            This mysterious fuel processor is the DIL 40 Intel Chip, not the 68 pin plcc chip that looks like the 80c535.
            PRJ, can you please tell me which pin of DIL 40 Chip is the pulse input? I really can't find anything about it.
            Regards
            • -ice-
              • Oct 2011
              • 173
              Maybe the pulsewidths are transferred digitally to the fuel processor. I only measured two io-ports which are directly connected to the 80c535. And they seem to be inputs!
              And yes it is boring, when i'm talking with myself.
              Regards
              • prj
                • Mar 2010
                • 6308
                It does not work the way you think it does.
                S702 is an IO extender memory mapped to upper XRAM addresses of S700.
                Pulsewidth is copied from S700 to S702, and S702 outputs it to P0 of S750, from which P1.0-P1.4 are TI1-TI5.
                You really need to understand the S702 chip to get anywhere There are tons of unused inputs, PWM outputs and other funky stuff on it.
                • Acki
                  • Mar 2014
                  • 302
                  Nice progress here!
                  I have "only" a V8 but I'm not motivated to open IDA over x-mas
                  From my side, when I work - lets say 4-6 weeks - on the assembler code I didn't get big progress at the end, a break helps me a lot because I have the chance to get a new view after looking the code again
                  • -ice-
                    • Oct 2011
                    • 173
                    Hey Acki, nice to hear from you
                    The most interessting part at the moment is IE_1, where Airflow counter value comes in (RAM_42/43). Then some calculation is made with some constants of the constants block and injector pulsewidth comes out (RAM_5e/f). These are also the constants which vary alot between aan and adu bins.
                    For me it's difficult to see the math behind it.
                    prj: ok, i assume this io-extender uses the upper adress lines, which aren't used by x-ram. Sure is, that it contains the adresslatch for the lower adressbits (ALE Pulse from 80c535)
                    when 16 bit dptr adress is used to make an movx access, thats what i think is the communication with the fuel prozessor
                    Regards
                    • Acki
                      • Mar 2014
                      • 302
                      I have found some similar stuff in the Bosch yahoo group.
                      But it's more or less guessing.
                      I have to make a desktop ECU to play with some kind of data logging to see a little bit what happens.
                      • prj
                        • Mar 2010
                        • 6308
                        I don't see what's difficult. 16 bit load x 16 bit enrichment = pulsewidth.
                        To understand math it is good to define all the simpler routines, like SHIFTLEFT, SHIFTRIGHT, MULT8x16, MULT16x16, DIV16x8 etc.
                        No, DPTR has nothing to do with it. You can access xram either by moving the high byte to P2 and then the low byte to R0 for example, or you can move the entire thing to DPTR. It makes no difference which way you do it from the end result perspective..
                        • -ice-
                          • Oct 2011
                          • 173
                          Hi,
                          A question concerning the AFM: The RS2 has a different R201 Resistor which is part of a voltage devider in front of the u/f conversion. In my calculation the output frequency is higher with R201 for a constant aiflow at th MAF.
                          Thats exactly the other way i expected it. The ADU has more airflow, so i thought they would use the resistor devider the keep the numeric value of the airflow small even at high airflow-rates.
                          Can anybody tell the logic behind this?
                          Bye
                          • prj
                            • Mar 2010
                            • 6308
                            Your calculation is wrong, that's all there is to it.
                            Maybe Ohm's law needs a little revisiting?
                            • -ice-
                              • Oct 2011
                              • 173
                              Maybe i've made a mistake measuring...
                              R200 is on top of the devider, R201 is on bottom connected to ground. R200 is 4,86 kOhm, R201 for AAN 5k6, for Adu 6k2
                              Uvco = Uinput* R201/(R201+R200)
                              The devider ratio is 0,5353 for AAN and 0,5605 for ADU
                              ..or a mistake calculating.
                              But thanks for your answer
                              • prj
                                • Mar 2010
                                • 6308
                                It's 6k2 for AAN and 5k6 for ADU, and the divider is 202/201. 200 has nothing to do with it.
