Ok so PRJ, kymi or -ice-, i found how the map lookup "table" in the boost chip is used and what maps are used from a corresponding read routine, I found the ADC reads and i am in the process of find which is used to read map tables and how the other are used. The thing is, i don't want you to tell me which ADC read is what but hint on how can I find which is what sensor input?
Because this is specific to the hardware implementation, right?
Also, a couple maps are visible if you search enough, but it semmed that not every one of them are used, am i correct? Are there duplicates?
Thanks
Thanks
