Hi,
im trying to understand the obd subroutines
We know that the ECU responds with 0x55h after the "wake up" part. The UART is configured to 9600 Baud. SCON 0E8h and SMOD in PCON = 1. The two following bytes sent by the ecu aren't hardcoded (i dont know them, because i haven't logged the serial communication with a running ecu yet). The ecu waits now for an acknowledge (ff-last byte sent)
In this code area (around 0x5548) the typical vagcom strings are loaded (4a0...). There is one adress called very often after loading such data: 0x59f2. Am i right to say it's a kind of uart_send_char procedure? I think finally it sends contents of 35h.
I searching for the part where it loads the block data which are demanded by vag com. I guess there must be a sort of switch case structure which selects the data to send.
Grettings
Grettings
