I think it's a problem with the galep3.
When I write with EmUtility first, read it again with EmUtility, the bin file is still correct and the same. The Galep3 Sofware still "sees" this offset.
P.S. I am working still with the 27c256 non buffered eprom and 551aa definition. The 0x7ff have nothing to say...
I see also the calculation of load. It's the only codepart where the load-variable is assigned with a calculated result (and not with fixed values...)
