It's a few post up.
G4 & G28 Signals
Originally posted by quattro-nick View Postanswer is already on
520hp-635 nmPaul Nugent
@ s2central.net:about transmision,for now i drive with a cbl 6 speed (urs4) gearbox but i already bought a rebuild dsy gearbox to put in the car .rear diff and driveshafts front and rear (100 mm) still origional
@diese ldes:yes,i use a sachs raceclutch with a organic disc like on post 38
so yours was slipping with this setup?audi coupe quattro b2 2.2 20vt project (573hp-626nm)
TWINCHARGED power,zero lag
AEM W/M injection
Quattro nick. I was using the sachs racing 4 puck friction disk with a spec pressure plate. Like this.
But the spec pressure plate is very light and so not enough clamping force and was slipping at 2 bar boost. I was using the spec pressure plate as I was sent the wrong sachs pressure plate originally and had the spec one in my store of stuff. Now its all sachs racing. Hopefully it will hold...
