G4 & G28 Signals
  • diesel des
    • 3896
    #31
    It's a few post up.
    • quattro-nick
      • Sep 2012
      • 1746
      • Country: Belgium
      #32
      i use this clutch(with organic disc) without problems for now
      TWINCHARGED power,zero lag
      AEM W/M injection
      • diesel des
        • 3896
        #33
        That's the same pressure plate I'm using now. How much torque it's going through yours?
        • quattro-nick
          • Sep 2012
          • 1746
          • Country: Belgium
          #34
          answer is already on
          520hp-635 nm
          AEM W/M injection
            Originally posted by quattro-nick
            good for you !
            picture of the new pin?
            it was above
              #36
              520hp-635 nm
              Impressive - any other transmission modifications to speak of ???
                Originally posted by newsh
                it was above
                It was but it is *very* difficult for us to see in the photo what you saw in real life.
                • diesel des
                  • 3896
                  #38
                  Good stuff. And that's with the full organic circular friction disk? Like this one.
                  I'm using the 4 puck sintered job.
                  • diesel des
                    • 3896
                    #39
                    Does that help?
                      Originally posted by diesel des
                      Does that help?
                      Yup. Looks like its all excited like, with a little stiffy.
                      • diesel des
                        • 3896
                        #41
                        Oh dear lol. As long as the sensor is excited then I'm happy.
                        • quattro-nick
                          • Sep 2012
                          • 1746
                          • Country: Belgium
                          #42
                          @ s2central.net:about transmision,for now i drive with a cbl 6 speed (urs4) gearbox but i already bought a rebuild dsy gearbox to put in the car .rear diff and driveshafts front and rear (100 mm) still origional
                          @diese ldes:yes,i use a sachs raceclutch with a organic disc like on post 38
                          so yours was slipping with this setup?
                          AEM W/M injection
                          • diesel des
                            • 3896
                            #43
                            Quattro nick. I was using the sachs racing 4 puck friction disk with a spec pressure plate. Like this.
                            But the spec pressure plate is very light and so not enough clamping force and was slipping at 2 bar boost. I was using the spec pressure plate as I was sent the wrong sachs pressure plate originally and had the spec one in my store of stuff. Now its all sachs racing. Hopefully it will hold...
                            • quattro-nick
                              • Sep 2012
                              • 1746
                              • Country: Belgium
                              #44
                              with the sachs race clutch you get a heavy clutchpedal
                              but i solved this with a little vacuumbooster on clutchpedal
                              AEM W/M injection
                              • diesel des
                                • 3896
                                #45
                                That's the thing. This sachs racing pressure plate, while heavier than the spec one, isn't that hard to push. It's lighter than the south bend clutch I used to have but a fair bit.
                                The vacume assisted clutch sounds interesting! Like a truck. Have you any pictures or details of it?
